Home > Help Needed / General Tech Chat > what turbo?????
turboandy
Member #: 1735
morton, lincolnshire
hi guys just looking for advice on what turbo unit to get for my 998cc conversion. ive looked at a T2 from a fiesta or R5. also a TD04 from a 1993 WRX scooby. a TD04 15G from a toyota starlet. TD04 11G, im wanting to fit the turbo unit over the clutch housing so size isnt the problem any help would be great thanks
turboandy
Member #: 1735
or even the K03 or K04 turbo thanks
probably best to start with a search
Depends on what boost you are planning on running.
If you are just running 8-12 psi then you want a turbo that will flow around 10-12 lb/min at 1.5 to 2:1 pressure ratio.
turboandy
Member #: 1735
i will run low boost to start with as the engine is completly standard
I would stick with the T2 from the R5GTT if I was you then. Known to work well.
Have a read of this:
http://www.turbo-mini.com/62147.html
20 Hour 998 turbo conversion using a t2
turboandy
Member #: 1735
i will look for a T2 then thanks guys
