Home > 998cc > dump valve fitting kit
turboandy
Member #: 1735
morton, lincolnshire
saw this ebay item today what do you guys think is it worth it? i was thinking of getting the carb to manifold adaptor instead but not sure
Prawn
Member #: 5232
basingstoke
no link posted mate.
what does the 'fitting kit' involve exactly>?
Couple of pipes, few clamps and a t piece at a guess.
I would price up the pieces seperatly and see if you can do it cheeper. Also triple check that the kit has the right size pipes for your setup
turboandy
Member #: 1735
ooops sorry forgot the link
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?Vie...em=370210630976
You'll have to weld the provided "spout" to the plenum, plus it's a fair bit of money for just a dump valve & a couple of hoses.
Prawn
Member #: 5232
basingstoke
I'd say that's of just about no use to you at all!
If you want to install a DV without modifying the plenum, the only option is to run a full size T-piece in your cold side IC line with a 1'' take off, then hook this up to the DV using a 1'' silicon coupler. then rig up the vacuum feed from the inlet as normal
This would do it if you wanted to use a metal T:
http://cgi.ebay.co.uk/TWIN-PISTON-DUMP-VAL...93%3A1|294%3A50
Or alternatively, you could simply replace a normal silicon coupler for one with a DV take off like this:
http://cgi.ebay.co.uk/63mm-2-1-2-ID-T-Piec...93%3A1|294%3A50
alernatilvly you can get silicon T's
minivan rick
Member #: 5645
middlesex ( near heathrow )
very helpfull thank you ......
Don't go slow !!! Go Turbo :))))))
Mr Joshua
Member #: 1954
Luton Bedfordshire
The kit from Minispeed comes with the sandwich plate with the vaccum line fitted to boot.
Own the day
turboandy
Member #: 1735
thanks guys very helpful, one other question were do i put the vacumm pipe in the inlet? dont seem to be anywere for it?
somwhere on the inlet manifold.
Mr Joshua
Member #: 1954
Luton Bedfordshire
Was down at the Ace Cafe and spotted a Turbo with the vaccum taken from where the part throttle lean off pipe plugs into the carb *surprised*. The owner says it works just fine (obviously his setup was modified so as not to need the part throttle lean of pipe)
Own the day
on a lot of (all?) Hif's the vacum port for the dizzy works diferent to ordinary su's so can be used for the dump valve.
