Home > Help Needed / General Tech Chat > front bumpstop fitting!!!!
1972-ANGUS
Member #: 3894
sallys gap. garden of Ireland
Hi guys,
sorry to post such a 10yr old's question!
But it appears, that after spending what seems the better part of my life, changing out my top arm bearings, i now have to turn my subframe towers inside out to get at these nuts which hold on these tower mounted bump stops.
Can it be so *surprised*
Can it be done with the suspension complete?
regards
Colin
PaulH
Member #: 2340
Dublin Ireland
If its the 2 bolt type you will have to fab a spanner to get at the nuts, OR
you could just cut the old one off with a suitable spinny thing and fit the singal bolt type :)
On 17th Feb, 2009 Rob H said:
1972-ANGUS
Member #: 3894
cheers paul,
i take it that its a right pain?
it got knocked off after finishing a full suspension swop!!
just a nut on the back, with a bent spanner then?
i think thers 2 x 5/16" nuts,
as paul sugests, i just whack them off with a hammer leaving the fixing plate and fit hydro type bumpstops to the top arm.
1972-ANGUS
Member #: 3894
thanks lads, ill see what i have in stock and bash away so.
The way I do it, just grind through the "pip" visible from the wheelarch side, assuming the rubber block has fallen off and disappeared! When you have ground the weld off, knock the remains of the stud away from you with a hammer and punch, then fit the new one.
Mr Joshua
Member #: 1954
Luton Bedfordshire
I know its a pain but I was faced with the same problem. Bit the bullet and took it apart only took quarter of an hour.
How much fafing around and time will it take to create a work round?
Own the day
PaulH
Member #: 2340
Dublin Ireland
2 mins with a grinder IMHO *tongue*
Mr Joshua
Member #: 1954
Luton Bedfordshire
Barbarian!!!!
Own the day
Not really. The bump stop is knackered anyway, so either do battle with a rusted stud and nut, using triple jointed fingers, or 2 min with the grinder and you are ready to fit the new one.
Mr Joshua
Member #: 1954
Luton Bedfordshire
Budweiser. point conceeded.
Own the day
