Home > General Chat > Up $hit creek without a Turbo Rebuild kit!
Got the ancilleries and what not back on the car last night, fired her up and all i saw was white! Just thick white smoke.
So i took the lambda bung out and felt inside the exhause elbow. oil! Groovey. So im praying that its the turbo and nothing else, i whip the turbo and manifold off, get the missus to turn the engine over and all i see is oil coming out of the turbine housing.
So it looks like the seals are kaput. Time for a fast rebuild and get the rest of the car sorted before Avon!
Just what i needed.
Does anyone happen to have a Gt17 Rebuild handy that i could pinch??
Mike
Damn! *frown*
Exactly! Im not going to avon without my car!!!
PaulH
Member #: 2340
Dublin Ireland
I have a spair GT 17 Mike PM me if your intrested I could have it UPS to you by end of week
On 17th Feb, 2009 Rob H said:
Ive just seen your in ireland lol
Ive pmed you anyways
evolotion
Member #: 83
Glasgow, Scotland
check your oil drain, on cranking you shouldnt be getting oil pissing out the turbine even if the seals are gone. imho ofcourse!
Denis O'Brien.
Ahh, well when i tested the turbo to see if it was buggered, i popped my finger over the drain hole, but i would have thought the oil would have pushed my finger out of the way! Come to think of it, the oil drane is the only thing that i have changed. The car didnt smoke before i took the ancilleries off.
Ideas anyone?
is the drain blocked or kinked,
carl
Not that i can see, it is slightly elaborate, with a couple of connection as it goes in through the speedo drive. Ill alter it, the turbo does have a fair amount of play in it. Up and down only!
The oil drain isn't under pressure, so it wouldn't push your finger off, it's only gravity drained, so needs to be as unrestrictive as possible.
I try freeing it up, carl i might have a little job for you tonight *wink*
yeah i thought i had a goosed turbo, turned out to be my drain.
evolotion
Member #: 83
Glasgow, Scotland
my drain went into my block on a 90 degree fitting, oil backed up and it smoked. cut an oval hole in the block and sikaflexed an angled bit of pipe in, and no smoke since .. bodge tastic, but the point is the drain needs to be very down hill and very free flowing. remember the turbo core"breaths" through teh drain too. so there has to be room for air and oil *wink*
Edited by evolotion on 2nd Jul, 2009.
Denis O'Brien.
Well after a visit to carls today i discovered my drain was kinked *Clapping* whoopsie!
Carl made me one up and ive just tried it and guess what, no smoke! Well smoke at first (burning off excess in the turbo)
Another Mysterty solved! TM to the rescue!
Cheers for the suggestions boys and thanks to car for the drain help! *wink*
Edited by MikeRace on 2nd Jul, 2009.
shane
Member #: 1246
Lowestoft, Suffolk.
Well done that man!
Shane
Mad how many of us have been caught out with this!
I dread to think.
Ready for Avon then??
Lol,. i recon so, ive been busy all last night and will be all next week.
Ill let you know if i need that A Frame matey! I think i can get a trailer but will let you know either way!
