Home > Help Needed / General Tech Chat > zx9 nija carb help needed
turbochargedstu
Member #: 908
gateshead
does anyone know which jet is the idle one in the float chamber? gonna try opening it up a bit but i dont know which one it is. i know the main is in the middle.*oh well*
balls to the blower!!!
fab
Member #: 100
Parisien Turbo Expert
Paris' suburb
When you're look at it from underside you have float valve, main jet , pilot jet on the right and then starter jet on the left,
then you have the idle mixture screw, generally plumbed, just before the carb outlet ( engine side) underside,
and pilot air jet at the mouth of the carb, left one (brass)when you're look at it straight in his normal position
Edited by fab on 1st Jul, 2009.
fab
Member #: 100
Paris' suburb
I realize it's confusing as I had troubles with carb just in face , tell me if you prefer a pic, will make.
Fabrice
