Home > Technical Chat > T3 actuator on a T2
sid
Member #: 6376
oxon
as the title, i have a nice shiney avonbar 12psi actuator and i was thinking of changing out to a T2 turbo.
i have had a measure up and i can make it fit with a bit of bracket work but i just wanted to check there wasnt some reason that i was missing that would stop it working.
any ideas would be helpfull *happy*
There's no problem. I use the Avonbar billet actuator with a T2. You'll just have to make a bracket up.
Phil.
sid
Member #: 6376
oxon
cheers phil *happy*
No worries. I assume you've got the bulkhead box fitted though ?
If you're using the Mirage manifolds it may still fit, but I couldn't confirm it.
Edited by Turbo Phil on 1st Jul, 2009.
sid
Member #: 6376
oxon
still making the manafold, going to try and sidemount it with the late shape servo still there, if it fails i want to keep the turbo there just make the servo remote.
anyhow will get the build log up when i get a chance to write it up, but low on time atm *happy*
again cheers for the help though.
JT
Member #: 637
Hertfordshire
hi
sorry to go off topic a little bit but...
what psi does the standerd actuator go up to on a R5GT turbo (water cooled type)
thanks
josh
My build thread..
shane
Member #: 1246
Lowestoft, Suffolk.
I had 12psi on my old R5, believe it was a std actuator.
Shane
JT
Member #: 637
Hertfordshire
was with a bleed valve?
thanks
josh
My build thread..
shane
Member #: 1246
Lowestoft, Suffolk.
Nope, just alot of preload on the actuator.
Shane
