| Home > Help Needed / General Tech Chat > Clutch issues | |||||||
![]() 730 Posts Member #: 1791 Post Whore Cranleigh, surrey |
1st Jul, 2009 at 11:24:07pm
Well as avon park is approaching i thought i'd better put a new plate in as mine was starting to squeal a little. So fitted the new plate etc and all was well. Forgot to cable tie the old slave cylinder into place and now i can't seem to get a decent pedal? Its pre-verto, double grey with a sintered plate and force racing clutch arm, I tried blocking it and bleeding through but still nothing?
"Cars are a lifetime of pain" |
1st Jul, 2009 at 11:46:04pm
http://www.manchesterminis.co.uk/index.php...sosinfo&sosid=9 :) |
2nd Jul, 2009 at 02:22:14am
Cable tie? Own the day
2nd Jul, 2009 at 08:01:28am
just to hold the clutch slave arm from falling out and getting this situation..... "Cars are a lifetime of pain" |
2nd Jul, 2009 at 08:54:57am
Stef, are you trying to bleed it dissasembled ,if so put everything back as was inc return spring to slave and blead as normal,
2nd Jul, 2009 at 09:05:08am
No, its all assembled, return spring is un-attached as it connects into the end of the bleed nipple. suppose i could connect it somewhere else?
2nd Jul, 2009 at 11:26:38am
Check the clearance between the return stop and the arm, sounds like its too big if the bite point is very low. Own the day
2nd Jul, 2009 at 12:46:39pm
but that shouldn't have changed, i only replaced the clutch plate. for a new plate, so i would have thought it was slightly thicker. but nothing major, maybe a couple of mm as the last one wasn't that worn! "Cars are a lifetime of pain" |
2nd Jul, 2009 at 01:24:00pm
1mm clutch plate wear = approx 4-5mm adjustment at the 7/16" bolt return stop which in turn = around 20mm at the pedal. On 28th Aug, 2011 Kean said:
2nd Jul, 2009 at 02:44:02pm
Check the clearance! Own the day
19th Aug, 2009 at 11:42:22pm
How did you cure this stef as i currently have this problem with my own clutch! Its doing my head in! |
20th Aug, 2009 at 07:34:55am
Hmm....had to adjust the arm out on the bolt. simple really, just didn't check it. knob. "Cars are a lifetime of pain" |
20th Aug, 2009 at 09:53:08am
LOL,
