Home > Technical Chat > synthetics vs mineral oils
sx_turbo1
Member #: 4608
"Member"
i copied this from another site, the guy writing this is the dogs danglies when it comes to oils.
SYNTHETICS vs MINERALS
Oil is the lifeblood of your vehicle's engine. For decades conventional petroleum
oils have been providing adequate protection for all of our vehicles.
The key word here is adequate. Petroleum oils, for the most part, have done an adequate job of protecting our engines from break down. If you change it often enough, you can be relatively sure that your car will last 100,000 to 150,000 miles without a serious engine problem - maybe even longer.
The real question is, why settle for adequate when something better has been available for
about 30 years?
Today's engines are built for better performance, and, although petroleum oils are designed for better protection and performance today than they were 10 or 20 years ago, there is only so much that can be done. Today's engines need high performance lubricants, and the only true ones available are synthetics.
Conventional petroleum oils are insufficient for use in today's vehicles primarily because they are manufactured from a refined substance, contain paraffins (wax), sulfur, nitrogen, oxygen, water, salts and certain metals. All of these contaminants must be refined out of the basestock in order for it to be useful for use within a lubricant.
Unfortunately, no refining process is perfect. Impurities will always remain when any refining process is done. It simply isn't economical to continue to refine the oil again and again to remove more impurities. If this was done, petroleum oils would cost as much as synthetic oils do.
There are many components of petroleum oil basestocks which are completely unnecessary for protecting your engine. They do absolutely nothing to enhance the lubrication properties of the oil. In fact, most of these contaminants are actually harmful to your oil and your engine.
Some of the chemicals in conventional petroleum lubricants break down at temperatures well within the normal operating temperature range of your engine. Others are prone to break down in these relatively mild temperatures only if oxygen is present. But, this is invariably the case anyway, especially since oxygen is one of the contaminants within petroleum basestocks.
These thermally and oxidatively unstable contaminants do absolutely nothing to aid in the lubrication process. They are only present in conventional petroleum oils because removing them would be impossible or excessively expensive.
When thermal or oxidative break down of petroleum oil occurs, it leaves engine components coated with varnish, deposits and sludge. In addition, the lubricant which is left is thick, hard to pump and maintains little heat transfer ability.
In addition, petroleum oils contain paraffins which cause dramatic oil thickening in cold temperatures. Even with the addition of pour point depressant additives, most petroleum oils will begin to thicken at temperatures 10 to 40 degrees warmer than synthetic oils.
As a result, petroleum lubricants will not readily circulate through your engine's oil system during cold weather. This may leave engine parts unprotected for minutes after startup. Obviously, significant wear can occur during this time frame.
Even when all conditions are perfect for conventional oils to do their job, they fall far short of synthetic oils. Part of the problem is that (because of their refined nature) petroleum oils are composed of molecules which vary greatly in size. As the oil flows through your vehicle's lubrication system, the small, light molecules tend to flow in the center of the oil stream while the large, heavy ones adhere to metal surfaces where they create a barrier against heat movement from the component to the oil stream. In effect, the large, heavy molecules work like a blanket around hot components.
There is also another effect of the non-uniformity of petroleum oil molecules which reduces their effectiveness. Uniformly smooth molecules slip over one another with relative ease. This is not the case with molecules of differing size.
Theoretically, it might be somewhat similar to putting one layer of marbles on top of another (if this could easily be done). If the marbles were all of the same size, they would move over one another fairly easily. However, if they were all of differing sizes, the result would be much less efficient.
In the case of petroleum oils this inefficiency leads, ironically, to added friction in the system (the very thing that lubricants are supposed to reduce). Hence, petroleum oils are only marginally capable of controlling heat in your engine. Considering that motor oil does nearly 50% of the cooling of your engine, that's not a good thing. But,
This being said, petroleum oils are “adequate” for the purpose of protecting your engine, if you don't mind a shorter vehicle lifespan, inconvenient oil changes, or decreased engine
performance. Under normal circumstances, most vehicles lubricated with petroleum oil should run satisfactorily for 100,000 to 150,000 miles without serious incidence.
If you like the hassle of changing your oil regularly, and you are only looking for marginal
performance for the next 100,000 miles or so, petroleum oils are definitely the way to go.
Assuming that you don't relish the idea of changing your oil every 2,000 miles or and are looking to keep your “pride and joy” in tip-top condition then these are the main areas where synthetic oils surpass their petroleum counterparts.
Oil drains can be extended
Vehicle life can be extended
Costly repairs can be reduced
Fuel mileage can be improved
Performance can be improved
Synthetic basestock molecules are pure and of uniform size. This is because synthetic basestocks are designed from the ground up with the sole purpose of protecting your engine. Nothing is added if it does not significantly contribute to the lubricating ability of the oil.
In addition, in top-quality synthetics, no component is added which might be contaminated with any substance that might lessen the lubricating qualities of the oil. In other words, manufacturers of these premium synthetics implement very strict quality control measures to insure no contamination.
Not only that, synthetic basestocks are designed so that the molecules are of uniform size and weight. In addition, synthetic basestock molecules are short-chain molecules which are much more stable than the long-chain molecules that petroleum basestocks are made of. This significantly adds to the lubricating qualities and stability of the oil.
EXTENDED OIL DRAINS
Stable Basestocks
Synthetic oils are designed from pure, uniform synthetic basestocks, they contain no contaminants or unstable molecules which are prone to thermal and oxidative break down.
Moreover, because of their uniform molecular structure, synthetic lubricants operate with less internal and external friction than petroleum oils which have the non-uniform molecular structure. The result is better heat control, and less heat means less stress to the lubricant.
Higher Percentage of Basestock
Synthetic oils contain a higher percentage of lubricant basestock than petroleum oils do.This is because multi-viscosity oils need a great deal of pour point depressant and viscosity modifying additives in order to be sold as multi-viscosity oils.
Synthetic oils, require very little in the way of pour point depressants and viscosity
modifiers. Therefore, synthetic oils can contain a higher percentage of basestock, which actually does most of the lubricating anyway. More basestock leads to longer motor oil life.
Additives Used Up More Slowly
Petroleum basestocks are much more prone to oxidation than synthetic oils, oxidation inhibitors are needed in greater supply and are used up very quickly. Synthetic oils do oxidize, but at a much slower rate therefore, oxidation inhibiting additives are used up much more slowly.
Synthetic oils provide for better ring seal than petroleum oils do. This minimizes blow-by and reduces contamination by combustion by-products. As a result, corrosion inhibiting additives have less work to do and will last much longer than within a petroleum oil.
Excellent Heat Tolerance
Synthetics are simply more tolerant to extreme heat than petroleum oils are. When heat builds up within an engine, petroleum oils quickly begin to burn off. They volatize. In other words, the lighter molecules within petroleum oils turn to gas and what's left are the large petroleum oil molecules that are harder to pump.
Synthetics are resistant to this burn-off. They will tolerate much higher engine temperatures.
EXTENDED VEHICLE LIFE WITH FEWER REPAIRS
Heat Reduction
More often than not, vehicle life is determined by engine life. One of the major factors affecting engine life is component wear and/or failure, which is often the result of high temperature operation. The uniformly smooth molecular structure of synthetic oils gives them a much lower coefficient of friction (they slip more easily over one another causing less friction) than petroleum oils.
Less friction, of course, means less heat in the system. And, since heat is a major contributor to engine component wear and failure, synthetic oils significantly reduce these two detrimental effects.
In addition, because of their uniform molecular structure, synthetic oils do not cause the "blanket effect" which was mentioned earlier. Since each molecule in a synthetic oil is of uniform size, each is equally likely to touch a component surface at any given time, thus moving a certain amount of heat into the oil stream and away from the component. This makes synthetic oils far superior heat transfer agents than conventional petroleum oils.
Greater Film Strength
Petroleum motor oils have very low film strength in comparison to synthetics. The film strength of a lubricant refers to it's ability to maintain a film of lubricant between two objects when extreme pressure and heat are applied.
Synthetic oils will typically have a film strength of 500% to 1000% higher than petroleum oils of comparable viscosity. In fact, believe it or not, even though heavier weight oils typically have higher film strength than lighter weight oils, a 0w30 or 5w-40 weight synthetic oil will likely have higher film strength than a 15w40 or 20w50 petroleum oil.
Thus, even with a lighter weight oil, you can still maintain proper lubricity and reduce the chance of metal to metal contact when using a synthetic oil. Of course, that means that you can use oils that provide far better fuel efficiency and cold weather protection without sacrificing engine protection under high temperature, high load conditions. Obviously, this is a big plus, because you can greatly reduce both cold temperature start-up wear and high temperature/high load engine wear using the same low viscosity oil.
Engine Deposit Reduction
In discussing some of the pitfalls of petroleum oil use, engine cleanliness is certainly an issue. Petroleum oils tend to leave sludge, varnish and deposits behind after thermal and oxidative break down. They're better than they used to be, but it still occurs.
Deposit build-up leads to a significant reduction in engine performance and engine life as well as increasing the number of costly repairs that are necessary. Since synthetic oils have far superior thermal and oxidative stability than petroleum oils, they leave engines virtually varnish, deposit and sludge-free.
Better Cold Temperature Fluidity
Synthetic oils and other lubricants do not contain paraffins or other waxes which dramatically thicken petroleum oils during cold weather. As a result, they tend to flow much better during cold temperature starts and begin lubricating an engine almost immediately. This leads to significant engine wear reduction, and, therefore, longer engine life and fewer costly repairs.
IMPROVED FUEL MILEAGE AND PERFORMANCE
As indicated earlier, synthetic oils, because of their uniform molecular structure, are tremendous friction reducers. Less friction leads to increased fuel economy and improved engine performance.
Any energy released from the combustion process that would normally be lost to friction can now be transferred directly to the wheels, providing movement.
Vehicle acceleration becomes swifter and more powerful while using less fuel in the process.
The uniform molecular structure of synthetic oils has another performance enhancing benefit as well. In a petroleum oil, lighter molecules tend to boil off easily, leaving behind much heavier molecules which are difficult to pump. Certainly, the engine loses more energy pumping these heavy molecules than if it were pumping lighter ones.
Since synthetic oils have more uniform molecules, fewer of these molecules tend to boil off.
More importantly, when they do, the molecules which are left are of the same size and pumpability is not affected.
Guy
groan.... by chance was this guy called 'oil man' or 'oil guy' and happens to be a spam bot?
tadge44
Member #: 2500
Buckinghamshire
It doesnt matter how good the oil is you still need to change it often, because of the buildup of contaminants, so why pay £35 or more per gallon when you can buy decent oil at a third of that and change it more frequently.
sid
Member #: 6376
oxon
i agree with tadge44, my mini is a toy and gets serviced more than ever needed so cheaper oil gets used anyway.
if you are just lazy and dont want to service your car i guess that you could use the expensive stuff but meh its 50 year old technology that we are playing with so there is no snake oil in the world that can do away with atually looking after it.
anywho keep up the copy pasting :p
Has oilman got that desperate he has to use other names on forums now.....
Quite sad really.
I would always us the oil specified by the manufacturer. Non of that stated above applies to the Mini anyway, as we have the gearbox to lube too, which has a different requirement.
What is Oilmans agenda?
Trying to self advertise without paying for it, by posting text lifted from oil manufacturers websites on the various forums? Luckily we've avoided his attention this far.
Mr Joshua
Member #: 1954
Luton Bedfordshire
Not one I tell you not one bit of usefull information in that text, worse than Sunday school bible class. Thats half an hour Im not going to get back and I aint getting younger. And as stated of no use to CLASSIC engine builders!
Own the day
manifold
Member #: 1734
Lancaster
Looking at the amount of swarf and other metallic crap coming out of my sump plug every time I change the oil, I do it often as possible.
As the A series transverse gearbox runs in the same oil as the engine its something to bear in mind. A good comparison is that of the inline A series which suffers less.
Every time you miss change a gear theres a reasonable the chance more crap gets into the oil.
My thinking behind it is to use a reasonable mineral oil (cheaper) and replacing it often to eliminate the swarf issue as much as possible is as much as you can do.
Rather do that than scrap a couple of grand (or more) engine in short time.
Cheers.
David
Mr Joshua
Member #: 1954
Luton Bedfordshire
Bingo, as stated in another thread my brother told me that when he told a work colleague in the states that in England oil changes are done on average every 6k his eye nearly popped out of his head. Apparently other there its 3k at the extreme outside.
Basically the oil isn't in there long enough to get into any kind of state. its not uncommon for the oil to look almost the same as when it went in.
Regular oil changes wins hands down to prolong engine life IMHO
Own the day
Turbo Tel
Member #: 588
Delaware, USA
LOL on the 3k in the states, True, thats down to years of great brainwashing by the quicklube industry!!
I use 5k for my regular cars, annually on the old mini, (which probably works out under 2.5k) All of them get full synthetic, why not?, I spent tens of Thousands of dollars on engines and cars
$25 extra every oil change wont kill me!!
2 are well over 100,000 now and dont burn any oil.
Ben H
Member #: 184
Melton Mowbray, Pie Country
Change oil at 5k? Bollocks to that. I would say in the uk most NA cars have a 12k service and turbo cars have between 6k and 10k.
http://www.twin-turbo.co.uk
My A4 has 20K services (from the factory guidelines). Now it's hit 100k, it will be getting an oil change every 10k
My Golf just tells me when to take it to VW for its oil change. *hehe!*
And you don't get the bill either. Lucky F**ker!
I change the oil in my daily workhorse Astra every 3000 miles, the Mini around every 1500.
Richspec
Member #: 300
Cumbria
So whats that then Phil?, every couple of years in the Mini*tongue**tongue**happy*
Here for the craic..
Supercharged Arden powered
Just about ! Lol.
Ben H
Member #: 184
In my citroen diesel (HDI) it gets oil every 10 to 12k. It has done 195k miles so far so I will stick with that I think.
MONSTER HEDGEHOG
Member #: 4340
sideways, Birmingham
fortunatly i have advanced austin rover technology fitted, its refered to by the austin rover technical department as a "leak" *hehe!*
On 15th Dec, 2009 fastcarl said:
sell the lot to me for £70 pounds and i'll let you stand on the outside edge and look on my inner circle of closest frinds, lol
carl
FOR EVERY WELL THOUGHT OUT AND WELL EXECUTED PRICISION JOB EVER CONCIEVED, YOU CAN GUARANTEE THAT SOMEWHERE IN WALSALL OR THE BLACK COUNTRY THERE WILL BE A BLOKE TRYING TO ACHIVE THE SAME BY MEANS OF "ITIN IT WI LUMP AMAR"
tadge44
Member #: 2500
Buckinghamshire
I.ve been changing the oil in my HDI every 5k, but if you got to 195k with 10k oil changes Ben, the I will save myself some work ! Contrary to popular opinion I beleieve that it is necessary to shorten oil change intervals as the engine gets older.Those who think leakage is changing their oil haven,t thought about it.
MONSTER HEDGEHOG
Member #: 4340
i change the oil at about 2k - 3k intervals, but it depends what the cars been doing, i use cheap asda oil to flush as well, but use the halfords blue stuff, £13 aint bad for a gallon of oil *happy*
carl
miniboo
Member #: 2253
Las Vegas, Brit in the States
i change mine every 3K but i do it myself and it costs $20 inc a filter if that.
Plus i drive lots of motorway miles and in excessive heat.
So cheap to do it is rude not to.
I just did the shocks all round myself for $250.
