| Home > Beginners Tech > dizzyless ignition | |||||||
617 Posts Member #: 6558 Post Whore Pueblo, Colorado, USA |
13th Jul, 2009 at 05:25:15am
Hello all,
13th Jul, 2009 at 08:05:10am
For ignition only, no cam sensor is required, just the crank pulley mounted 36/1 trigger wheel and sensor.
13th Jul, 2009 at 08:20:05am
Rod, can you please point me in the direction of the "well documented" details ?. |
13th Jul, 2009 at 10:45:09am
All the extra features are in the MS2-Extra manual (this assumes you would be using MS2 as its better than MS1 and is needed anyway if you were ever to want to use the siamese code).
Edited by Rod S on 13th Jul, 2009. Schrödinger's cat - so which one am I ??? |
13th Jul, 2009 at 12:53:08pm
That should keep me quiet for a bit !! |
13th Jul, 2009 at 03:15:34pm
Okay, one more question. Is it possible to use the megasquirt 36-1 crank trigger? Just maching the pulley and bolt to accept it? And msd is uprated igition parts. You can have a coil pack, or I think they sell COP's as well, but I could be wrong. |
13th Jul, 2009 at 03:17:59pm
oh, sorry one more. For dizzyless ignition, would I leave the dizzy, or could I remove the whole thing? |
13th Jul, 2009 at 03:26:12pm
You can use anyone's 36/1 wheel (or machine the pulley) so long as you can fit a suitable sensor (pickup) to read it.
13th Jul, 2009 at 04:00:37pm
Thanks a lot for your replies. If I remove it I can always put it back in later. Do you need the whole dizzy for the phase sensor, or just the drive spindle?
13th Jul, 2009 at 04:07:24pm
Have a look at the various threads by Paul S and me, we both did it different ways but both based on the bottom half of the dizzys. Schrödinger's cat - so which one am I ??? |
13th Jul, 2009 at 04:14:41pm
Alright, awesome. Thanks for your help, I'll be on here a lot, as I still need to finish reading the threads. I'm 3/4 the way through the EFI section. If I have any more questions yout two seem to be the major guru's 'round here.
14th Jul, 2009 at 03:38:11am
Okay. I have another question. When I wire up my MSII where do I get power supply from? Also, I was reading some of the stuff, I believe off the megasquirt manual, and it says that for coil power I need to take it off the fuel pump relay 12 volt power. I have no fuel pump relay. I'm still working on the mechanical pump, as I don't have enough power to warrant a better one. I'm thinking of using AEM's short pencil coil(COP design). Any comments or suggestions?
14th Jul, 2009 at 07:45:44am
Why are you so against the std Ford coilpack? Available for very little money even brand new, and does the job fine on 200bhp+ turbo cars. I personally wouldn't waste my money on anything fancy in the coil dept, its not needed.
14th Jul, 2009 at 08:48:46am
The best way to power it is as per the manual, or at least based on the recommended circuit in the manual.
14th Jul, 2009 at 03:05:17pm
I only need the coil pack then? Just run the BIP373 on the board, I believe, as that replaced the last chip they were using for that stuff? So, would you recommend then installing a electronic fuel pump, so that I can use the 12 volt feed? It woudln't be too hard to wire up.
14th Jul, 2009 at 03:19:41pm
Coilpack will be fine as stated but you need two ignition driver chips (igniters) installed as per the Extra manual to avoid needing the EDIS module.
14th Jul, 2009 at 05:12:05pm
Alright. Sounds great. 2 BIP373's and coil wired to the fuel pump relay. Thanks! As soon as I get s little positive cash flow I should be on my way... |
