| Home > Technical Chat > Which pistons | |||||||
85 Posts Member #: 4865 Advanced Member LUTON beds |
13th Jul, 2009 at 01:45:12pm
Hi all Im building a 1293 Turbo using mirage manifold with T2
13th Jul, 2009 at 01:52:07pm
If you can afford £400ish you could get some forged Accralites. Go direct though as they are cheaper than buying from Avonbar.
13th Jul, 2009 at 04:02:37pm
Thanks for that Iv gone 4 the forged |
13th Jul, 2009 at 04:18:57pm
What forged pistons? Accralite or Omega? If something is worth doing, it's worth doing half of. |
13th Jul, 2009 at 04:36:22pm
OT. You had better get a wriggle on then for MITP when you wanting this tank for Own the day
13th Jul, 2009 at 04:37:56pm
I went with the Accralite
13th Jul, 2009 at 04:39:26pm
Well done that man! If something is worth doing, it's worth doing half of. |
13th Jul, 2009 at 04:40:20pm
On 13th Jul, 2009 Mr Joshua said:
OT. You had better get a wriggle on then for MITP when you wanting this tank for |
13th Jul, 2009 at 04:44:00pm
Well I had best get it done then, got the fittings and pipe workwont take long ill make a start on it tonight, if your around come see the progress. Own the day
13th Jul, 2009 at 04:44:44pm
On 13th Jul, 2009 minimadmotorman said:
Well done that man! |
13th Jul, 2009 at 04:49:20pm
Good good Ill call you later I might drop by
Well I had best get it done then, got the fittings and pipe workwont take long ill make a start on it tonight, if your around come see the progress. |
13th Jul, 2009 at 04:50:19pm
There are times when I really dont like you Own the day
13th Jul, 2009 at 05:00:40pm
There are times when I really dont like you |
