| Home > Help Needed / General Tech Chat > Running problems. | |||||||
![]() 730 Posts Member #: 1791 Post Whore Cranleigh, surrey |
13th Jul, 2009 at 03:53:52pm
Seems to me, my car has a running problem at 5000rpm. I changed plugs, coil pack, checked the omex, checked the map sensor, It seems it just missfires at 5000 rpm and doesn't want to rev past it, load or no load. So i think its unrelated to boost (no load still does the same) but being a novice at fault finding i'm not really sure what to start with.
"Cars are a lifetime of pain" |
13th Jul, 2009 at 04:35:43pm
I'd be looking at your crank sensor, is the gap correct? Also is your pulley true, and not running on the piss. Team www.sheepspeed.com Racing
13th Jul, 2009 at 04:36:11pm
loosing its signal from the crank sensor? can you check on your ecu? rev limiter set wrong? (easy i know but may as well ask)
13th Jul, 2009 at 05:00:25pm
my next guess would be to check the voltage at the ecu and coil pack while the engine is missing, Also check the ecu earth is good.
13th Jul, 2009 at 08:01:03pm
funny you should say about the plugs, 2 and 3 were a little wet compared to 1 and 4, i was thinking because its wasted spark could it be a coil problem? i believe 2 and 3 are fired togeather? "Cars are a lifetime of pain" |
13th Jul, 2009 at 08:10:42pm
AFR when this happens?
Edited by Sprocket on 13th Jul, 2009. On 26th Oct, 2004 TurboDave16v said:
13th Jul, 2009 at 08:58:42pm
without getting on the rolling road i have no ideas of AFR's, I really need a wideband setup, sooner rather than later i think........any suggestions? "Cars are a lifetime of pain" |
13th Jul, 2009 at 09:02:17pm
try another coil pack, there cheap enough Team www.sheepspeed.com Racing
13th Jul, 2009 at 09:03:19pm
jim, what AFR meter do you use? vems? "Cars are a lifetime of pain" |
13th Jul, 2009 at 09:35:18pm
I use the AEM gauge, I don't recomend it to be honest, the 5v output does not relate to the display, it's about .5 ratio out. Team www.sheepspeed.com Racing
857 Posts Member #: 1778 Post Whore Northants |
13th Jul, 2009 at 09:41:08pm
Try vwspeedshop i've been looking and they are the cheapest place i can find in the uk for the innovate stuff. £199 for a lc-1 wideband with sensor and guage. |
13th Jul, 2009 at 10:23:55pm
is the output not configurable/ tweekable?
On 13th Jul, 2009 Jimster said:
I use the AEM gauge, I don't recomend it to be honest, the 5v output does not relate to the display, it's about .5 ratio out. On 28th Aug, 2011 Kean said:
13th Jul, 2009 at 10:34:16pm
no, I need to send it back to AEM, but there customer service is not the best. I've just altered my target AFR to compensite, I've checked it with others so I'm confident I'm not going to cause any damage. Team www.sheepspeed.com Racing
