| Home > Help Needed / General Tech Chat > fitting big nut that holds pinion gear on????? | |||||||
298 Posts Member #: 1357 Senior Member telford,shropshire |
13th Jul, 2009 at 08:44:55pm
hi chaps
'always keep a spare shot for a stray bird' |
13th Jul, 2009 at 08:46:43pm
engage 2nd and 3rd at the same tine bud "Turbo's make torque, and torque makes fun"
13th Jul, 2009 at 09:01:10pm
Or 1st and 4th.
13th Jul, 2009 at 10:08:18pm
I have read that you should engage 1st and 4th as apparently you can brake stuff in 2nd and 4th.
13th Jul, 2009 at 10:25:00pm
so how do i dis engage the interlock. found this on net earlier but did not say anything bout interlock so been rawling my ass off for past half hour trying to engage them!!
13th Jul, 2009 at 10:35:49pm
you need to whip the diff out, and twist the shaft so it's not engaged into the selectors, you can then tap gears to get it into 2 gears at once Team www.sheepspeed.com Racing
13th Jul, 2009 at 10:45:42pm
It's been a few years since I touched a box, oh er misses, but I think there's a little ball & spring held in by one of the diff side plates that you might need to remove. However it's been a while so I'm sure someone will correct me if I've got it wrong. Isambard Kingdom Brunel said:
13th Jul, 2009 at 10:52:45pm
Removing the diff side plate that holds the ball/spring in will allow you to pull the interlock sleeve out and hence disengage the interrlock, BUT, if the diff is still in, it's really difficult to see what you are doing.
13th Jul, 2009 at 10:52:51pm
jimster is that the shaft selector shaft you speak of, or the barrel. as ive turned this and can not get the interlock to disengage?? 'always keep a spare shot for a stray bird' |
13th Jul, 2009 at 11:05:29pm
done! thanks for the help guys much appreciated 'always keep a spare shot for a stray bird' |
13th Jul, 2009 at 11:07:31pm
You need to release the "barrel" by pulling the ball, plunger, and sleeve from behind the diff bearing side plate.
14th Jul, 2009 at 12:31:13pm
haynes say 1st and 4th, but i read somewhere that someone, somewhere, once upon a time, knew someones brother who stripped 1st using this method.
14th Jul, 2009 at 12:33:20pm
2nd stripped on my box using 2nd and 3rd, but I think thats just bad luck to be honest Team www.sheepspeed.com Racing
14th Jul, 2009 at 03:04:03pm
On 14th Jul, 2009 Jimster said:
2nd stripped on my box using 2nd and 3rd, but I think thats just bad luck to be honest exactly this has happened to me aswell! |
14th Jul, 2009 at 04:28:30pm
im slightly worried bout tightening the nut now!!!! its a new gear set so hopefully wud be ok???? right???? 'always keep a spare shot for a stray bird' |
14th Jul, 2009 at 04:36:59pm
Suck it and see, ive never really paid attention to the gears i use! Never had a prob. 1/4 Mile 14.3secs 96Mph Terminal 10psi of boost.
14th Jul, 2009 at 04:52:34pm
it's the only way todo it really, so you don't have many options. Team www.sheepspeed.com Racing
