Home > A-Series EFI / Injection > MED crank trigger
miniswordsman
Member #: 6558
Pueblo, Colorado, USA
Has anyone used the MED crank trigger? And if so, what's peoples thoughts on it? Worth it, or better to get one from somewhere else and mount it to the existing pulley?
-James
miniswordsman
Member #: 6558
or how about the Specialist components one? Can it be used with MS? I'm looking at both. The reason I'm considering the MED one is so that I can replace the pulley as well. The 850's didn't have a damper, so I would like to replace that as well.
-James
jbelanger
Member #: 831
Montreal, Canada
There's possibly a third option: http://trigger-wheels.com/store/index1.html. But that may not fit your application. And I don't have any experience with this product.
Jean
http://www.jbperf.com/
I think that the MED wheel is the best available, but I've not used one.
miniswordsman
Member #: 6558
I'll try it then. worst that will happen is I can tell everyone here not to use it, or tell you all that it's great!
-James
turbominij
Member #: 2104
Essex - UK
how was the damper/trigger wheel im looking to buy one for my engine which is the better option?
"Tuning should be a compromise between what is possible and what is necessary"
10)Thou shalt always quest for more power
miniswordsman
Member #: 6558
I'm still yet to try the MED, funds went out the window when my head blew.
nuukuus
Member #: 6857
Lieto / Finland
I have same sensor as MED use but self made braket.
Working ok.
Jani
1399cc, Eaton M45 supercharger, N2O system, compression ratio 9.23:1, boost pressure 0,8bar/11.6psi.
http://www.garaget.org/?car=176816
miniswordsman
Member #: 6558
How about the crank pulley? Is that from MED or no?
-James
