Home > Help Needed / General Tech Chat > Does anyone know whre my tape measure is?
Cos I fucking don't!
Got three of the buggers and can't find one. Was planning on hanging a couple of doors tonight, but after an hour wasted looking for the dam things I gave up and cracked open a beer.
I'm 100% that Jensen, my 1 and a bit year old has posted the one I had out somewhere, but asking him tomorrow morning is likely to achieve nothing.
AAAAAaaaaaarrrrrgggggggggg.
1293 sprite
Member #: 5449
Melton Mowbray
where you left it >_< ??
1293 88.8hp 82.2ftlb
17.3 1/4 @ 78 mph
Naturally Aspirated (for now)
the last place youll look?
Damn.
I have 3 tape measures and can never find any of them either!!!
Wife's handbag is where I know I can always find a tape measure as a last resort !
My wife uses them, then puts them somewhere else. Usually quite close to where they should be but completely out of sight!
Oli
Member #: 1910
Wilts
Have you look on the side?
I've looke on the side, top bottom and under. I even checked the letter box as it's my sons favorite place to put the keys.
Wifey doesn't have a handbag, but might check her work bag, good idea.
Jay#2
Member #: 648
Northern Ireland (ex AUS)
Are you sure?! This is unatural...
On 7th Nov, 2008 Nic said:
naeJ
m
i always can russle one up from under the drivers seat in my van, christ knows where they come from
theres obviously a bunch of worm hles leading to joes vans passenger seat lol
Jay#2
Member #: 648
That's like lost socks in the wash, they come out your navel as fluff.
naeJ
m
If it's not in the wifes handbag, it will be by the window that needs new curtains or on the floor where you need a new carpet.
Tool box, main chest, third draw down, with all the other measuring and marking out stuff??
sid
Member #: 6376
oxon
you should have a part of your body that you know the exact length of....
mearly place that on what ever you are measuring and calculate how many times it will fit on *happy*
Mini_Andy
Member #: 432
Sorry Will, i have it.
I lost mine a few weeks ago so 'borrowed' yours, i'll put it back under that pile of junk for you later.
Edited by Mini_Andy on 16th Jul, 2009.
Oli
Member #: 1910
Wilts
I guess if your hanging doors your measuring out for the hinges.... in which case cant you just use a 12inch rule lol?
Or has that walked of too? which is normally the case!
Turbo Shed
Member #: 30
Epsom, Surrey
i'm sure he has measured a body part but i understand it would take a long long time to measure a door!
Yes, in theory, but I have four folding doors to hang, so 12 hinges in total, plus lots of other measuring to make sure everything is straight. Would have been prone to errors using a 12" rule.
And although body parts could be used, I fine that temperature and excitability can massively influence the accuracy!!
turbominivanman
Member #: 1504
Westbury, Wiltshire
Wil.
Is it the one that Rob H is holding in Roberts people shots at Avon, 11th pic ?
Just a thought as there's one in his puddy by the look of it.
Richard.
shane
Member #: 1246
Lowestoft, Suffolk.
Did you have it before you lost it?
Shane
there is no reason whatsoever to need any measuring deivice when hanging a door, top hinge is 2x hinge length down form top of door and bottom hinge is 3x length up from bottom,midd hange is guessed,lol.
carl
