Home > General Chat > MG Midget 1/4 mile times
SAD_Man
Member #: 2538
I've noticed there are a few MG Midget owners on here and I just wondered if anyone knew what is the best 1/4 mile times recorded for any MG Midget (excluding silhouette type cars) but pretty much any other modifications allowed (Turbos / engine swaps) but retaining the central 'core' of the steel body.
Sorry for the Non Mini question *happy*
t2clubby on here ran at Avon over the weekend. you could ask him what times he ran *smiley*
Turbo Shed
Member #: 30
Epsom, Surrey
MG Midgets are cool, got the same engine as a mini but powering the right set of wheels
10 years ago there used to be a Rover K series powered midget , seriously modified, it was certainly using nitrous , but i don't know if it was turbo ,
i'm sure i saw it run an mid 11 sec pass,
Nick
Member #: 154
Midlands
you could do but he's got a clubby estate, lol.
steve1275 has got a midget though :)
Kean
Member #: 341
aka T2clubby
South Staffs
Just had to go check in the garage that my car hadn't morphed into a midget...
probably wouldnt be a bad thing, unless it was a circus midget that smelt of cabbage.
Doh! *surprised*
I knew who I meant. LOL
Steve1275's midget runs a T2 and a bif intercooler. Very nicely installed. Keeps smashing his diffs with the power *smiley*
steve1275
Member #: 951
Bromsgrove
Managed a 14.6 with 96 mph terminal at Avon,but wrong tyre pressures/cold tyres.The diff that kept breaking was a phantom grip-kept breaking the roll pin,letting the cross shaft escape!Tran-x now which was great at Avon.
'Where does the engine go?'
SAD_Man
Member #: 2538
Thanks for the replies,
Steve1275,
Is the TranX a ramp and plate diff, do you use 3.9 cwp?
Do you know the weight, hp and torque of your car?
I assume you are running 175ish width road tyres
Sorry for all the questions
steve1275
Member #: 951
Bromsgrove
The TranX is as you say.I'm using a 4.2 cwp,but with 14 in wheels tyres are 165/65.Power is around 160bhp,torque 150 ft.lbf.Weight is about 700kg
SAD_Man
Member #: 2538
Cheers Steve,
Do you think that the 14.6 is as quick as a your set up will go or is it early days? As I'm just trying to gauge what sort of power would be required for a high 12 low 13.
As always it's the traction aspect that's difficult to gauge but I would have thought an LSD equipped RWD car (tyres permitting) would be a good starting point compared to a FWD car.
What would a similar engine spec (160 hp / 150 lbs.ft) do in a road trim Mini? I guess a road trim Mini would be 650 kg ish? Also if on 10's they would also be 165 width tyres as well.
steve1275
Member #: 951
Bromsgrove
I'm a novice at this,so my times must be quite slow.Amidget will take 185 width tyres with spacers,so traction will not be a problem then.Maybe 200bhp to get into the 12s?
