| Home > Beginners Tech > VR sensor | |||||||
617 Posts Member #: 6558 Post Whore Pueblo, Colorado, USA |
16th Jul, 2009 at 08:27:13pm
What does vr stand for? MS recommends a VR sensor. Is this the same as a hall effect sensor? And what's the best one people have found to use for electronic ignition using MS as the power source?
16th Jul, 2009 at 08:29:47pm
VR is variable reluctance or something similar, most magnetic crank sensors off modern cars are one of these, except super modern stuff which are digital. A commonly used one is from a Ford, and can be fitted using a bracket, see link http://www.turbominis.co.uk/forums/index.php?p=vt&tid=201632
16th Jul, 2009 at 08:37:22pm
VR is variable reluctance and is VERY different to hall effect or optical.
16th Jul, 2009 at 08:42:16pm
although you can get hall switches that will work on toothed wheels,
16th Jul, 2009 at 10:28:29pm
So i can grab one when I get my coil pack and just do up a bracket to fit it then. Can I use one of the backplate bolts that are available, or even the alternator bracket on the block to hold down the sensor? What year fords should I stay away from? 2000 and older is what I should look for, or...
16th Jul, 2009 at 10:35:11pm
Your mounting bracket will need to be unique to the way you do the 36:1 wheel, mine is different to most because I wanted the sensor at the back of the engine.
![]() 1105 Posts Member #: 1504 Post Whore Westbury, Wiltshire |
16th Jul, 2009 at 11:17:43pm
James.
16th Jul, 2009 at 11:41:17pm
The SC bracket is for a sensor on the back of the crank though, isn't it? That's where the MED trigger is, which is the kit I think I'm going to use...
