Home > General Chat > Tooth numbers on Pre A+ laygear drive gear?
I'm curious what the tooth count is of the largest gear on both the 'S' and non S 4-synch laygear.
It is the pre A+ unit's I'm interested in.
Cheers.
fab
Member #: 100
Parisien Turbo Expert
Paris' suburb
17 t for the std ratio and
18 for the s/1275gt/ innocenti/princess close ratio.
be carefull there is two types pre a+ 14mm bearing and as A+ 18mm ones.
cheers
Fabrice
That's the first motion gear - I want the laygear numbers (I guess it's 25, 26 or 27)...
fab
Member #: 100
Paris' suburb
29,
the same as std ratio box, btu can't mix.
Fab
I seem to recall that the gear count was the same but the OD was very different as well.
