Home > 998cc > Safe Rev Limit
Right, now that I've put the turbo on the 998, I keep hitting the rev limit.
I originally built the engine for mpg, but having been under the bad influence of TM, I find myself ragging the poor engine at every opportunity :$
I've got the Minispares/Hypatec P20950 pistons with circlips.
Because of the circlips, I've limited the revs to 6k.
Am I being overly cautious or is 6k right?
Did you fit buttons to stop the clips getting out?
If NOT, then I'd say stick to 6k. In my youth the first vaguely performance orientated engine I ever built was a +20 1098cc A series, with a piper 270 cam, and a skimmed 12G295. With a centre main strap and a vernier timing gear set it cost me the bulk of my then meagre part time wages over about 8 months. I revved it to 6500rpm like the young 18 yr old hoodlum I was and it lasted about another 8 months before a circlip got out, and scored the bores to pieces, knackering it.
Turbo Shed
Member #: 30
Epsom, Surrey
mini se7en's rev to 10,000 if thats any help!
6 sounds very low, i'd have gone with 7 or 8 depending on the build
No buttons I'm afaid.
I'll stick to 6k until it comes out, then I'll fit some buttons.
jbelanger
Member #: 831
Montreal, Canada
A 1098 will have higher piston speeds and acceleration than a 998. I would think that would be significant enough to mean that 6.5k on a 998 would still be safe.
Jean
http://www.jbperf.com/
Everything else will be fine other than the circlips. TBH if they are new then the chances are the occasional sprint to 6,5K wont shorten their life in the short term.
I rev my 70k 998 engine to 7k when in a hurry but 5.5 is the usual. It is standard with pushfit slipper pistons.
As I mentioned at Avon, if I limited mine to 6k it wouldn't have done a 16second 1/4.
PaulH
Member #: 2340
Dublin Ireland
stick with 6 Paul.
On 17th Feb, 2009 Rob H said:
i just checked out the piston g's and speeds,
you only need to turn a 998 an extra 750 rpm to get to the same piston speed and g's. i was suprised at that.
Jean
