Home > 998cc > vacumm pipes
turboandy
Member #: 1735
morton, lincolnshire
hi guys, on my inlet manifold in the centre on top i have a vacumm pipe which im guessing goes too the brake servo? only problem is i dont have a brake servo so can this pipe be removed? and blanked off? also would this be a good place to put the vacumm pipe from the dump valve in?
thanks for ya help
If you're not using a servo, blank it off. Otherwise use it for a dumpvalve or boost gauge etc
turboandy
Member #: 1735
excellent thanks very much :)
