| Home > Technical Chat > SUCK OR BLOW ???? .....not that!!! | |||||||
280 Posts Member #: 4340 Senior Member sideways, Birmingham |
18th Jul, 2009 at 12:18:06am
On 15th Dec, 2009 fastcarl said:
sell the lot to me for £70 pounds and i'll let you stand on the outside edge and look on my inner circle of closest frinds, lol carl FOR EVERY WELL THOUGHT OUT AND WELL EXECUTED PRICISION JOB EVER CONCIEVED, YOU CAN GUARANTEE THAT SOMEWHERE IN WALSALL OR THE BLACK COUNTRY THERE WILL BE A BLOKE TRYING TO ACHIVE THE SAME BY MEANS OF "ITIN IT WI LUMP AMAR" |
18th Jul, 2009 at 12:26:34am
Blow through every time, allows intercooling.
![]() 3756 Posts Member #: 1709 I like granny porn. LONDONSHIRE |
18th Jul, 2009 at 12:29:25am
true that^^!! On 2nd Oct, 2009 Vegard said:
I bet my first wank came quicker than your first mini turbo These new modern turbos with their quick spool up time, would make the competition harder. On 15th Aug, 2011 robert said:
phew!!! thank you brett for smashing in my back doors .( not something i imagined writing... EVER) |
18th Jul, 2009 at 12:39:41am
very true, but i wasnt planing on intercooling it, i was thinking about 7psi max. ive got a free rolling road available so was thinking just bolt it to a standardish engine with a mg cam and see how it goes
18th Jul, 2009 at 11:21:03am
I'm eventually going to suck through my ADO16, should be fine for 10psi without an intercooler, although there obviously will be inferior to an intercooled setup.
55 Posts Member #: 6376 Advanced Member oxon |
18th Jul, 2009 at 11:21:59am
still go blow through though as they apparently start better, idle better and more inportantly you can have a dump valve |
18th Jul, 2009 at 11:47:06am
The dump valve thing is a reason NOT to have blow through... On 13th Jul, 2012 Ben H said:
18th Jul, 2009 at 12:24:55pm
lol, punto turbo recirc dump valves going on my clubman once i fit an intercooler
444 Posts Member #: 2885 Senior Member |
18th Jul, 2009 at 04:01:58pm
Ive read you get approx 10oC temperature drop over the venturi of a carburettor. So, running a draw through setup on any cold day where the temperaure is 10oC or less results in carb icing..
ive aquired a side mounted turbo assembly minus the intake system and cant decide wether to mount the carb so its blown thru or sucked thru.
