| Home > Wanted > I urgently require an mpi timing chain cover. | |||||||
20th Jul, 2009 at 05:36:03pm
the plastic fan keeps fouling the standard timing chain cover on my engine. I can't bash it in because then the cover touches the timing chain.
20th Jul, 2009 at 06:16:57pm
is spacing the fan out not an option? "Turbo's make torque, and torque makes fun"
20th Jul, 2009 at 06:25:51pm
I don't have a spare but, if it helps, what I did to a standard one was not bash it in, but I cut 6mm (depth) of the outer curve off all the way around with a thin cutting disk, sqaushed the wire mesh filling a bit, and welded a flat plate on. I've got a piccy if you want one. Edited by Rod S on 20th Jul, 2009. Schrödinger's cat - so which one am I ??? |
20th Jul, 2009 at 06:59:40pm
That would be useful rod. Always good for some information.
20th Jul, 2009 at 07:12:20pm
Photo was more to show the trigger wheel but you can see how I just cut the curved bit off the flame trap and welded a flat bit on.
