Home > Help Needed / General Tech Chat > Primary gear oil seal approx od and ID
I'm going to pickup some metal on the way home to make a tool to push this seal on. Does anyone know the approx OD and ID of the clutch oil seal?
t3gav
Member #: 229
Gavin@minispares.com
kent
53 and 70mm approx mate
i have the sykes tool if you want to copy it
graemec
Member #: 1424
Carnforth, Lancs
I guess the hard bit to copy would be the thin walled cover that goes over the primary gear splines, I presume it is spun rather than turned.
I can photo the putter on-er from the same set as the taker off-er if needed.
I think I'll be good now guys, thanks for the info
