Home > General Chat > Sealing a 45 dcoe spindle
Im sure I read somewhere you can get a kit to seal the Weber spindle for turbo charging but dont know where.
Any ideas where to get them from?
Paul
the dellorto dhla turbo carb has sealed spindles , would that kit fit in a 45 dcoe paul ? you could ask eurocarb in tilehurst .
johnK
Member #: 690
Norfolk
If anyone knows its "webcon"
JK
If Carling made Mini engines
Going turbo are we??
No
lockfast
Member #: 2775
Aberdeen
Supercharger then?
If your weber is a 151 or 152 series it is already good for blow-thru. If it isn't, it is probably easier to jump on one of these models than modify yours.
You still need to modify the top cover to pressurise the float bowl however.
GaryOS
Member #: 2810
Formally spanner181187
Dublin, Ireland
On 24th Jul, 2009 lockfast said:
Supercharger then?
I doubt it. It's difficult enough to fit a blow through supercharger setup under a normal minis bonnet, never mind a sprint.
On 30th Apr, 2010 Rod S said:
Gary's description is best
No, just wondered where to get them from
I recall the float bowls were also changed (and other little details) to cope with blowthru
Cheers Dave
i think pretty much all the available floats are foam filled now, i havebt seen brass ones in quite some time?
