Home > General Chat > I got a free GT2056
GaryOS
Member #: 2810
Formally spanner181187
Dublin, Ireland
Unfortunately it is a gt2056V though. I just thought I would post up pics incase it is of interest to anyone. It's now time for me to learn how to read compressor maps so that I can see if it will suite my E30. If it does, I have no idea wheather to attempt to control the vanes or simply use an external wastegate
As you can tell, it doesn't look much like the normal GT2056
EDIT: How the fuck did I type an "r" instead of a "v"?
Edited by GaryOS on 16th Feb, 2010.
On 30th Apr, 2010 Rod S said:
Gary's description is best
evolotion
Member #: 83
Glasgow, Scotland
dont dismantle this bit further, its a right fiddly pain in the rear to re-assemble :)
Denis O'Brien.
control the vanes. *Yes*
GaryOS
Member #: 2810
Dublin, Ireland
haha, it's too late. I already found out the hard way *frown* Thanks for trying to save me from my own over-enthusiasm though
I may do. I have been getting carried away and thinking of MS so it's not out of the question. The reason the turbo was replaced was due to a dead vane controller but I might pull it apart to see how it works
Who else is running a vvt?
evolotion
Member #: 83
Glasgow, Scotland
i believe fab was controlling one with a servo, and im sure someone on here has one with a wastegate and a ball-spring type boost controller??? but the name escapes me (sorry:( )
Denis O'Brien.
GaryOS
Member #: 2810
Dublin, Ireland
Fab and Joe are the only 2 I can think of. Joe is using an external wategate to control peak boost and an actuator to control the vanes at lower boost levels
evolotion
Member #: 83
Glasgow, Scotland
ah joe that was it .. i thought he managed to controll the boost outright with just the vanes now?? or have i been reading his thread wrong?
Denis O'Brien.
I dont know how well that exh housing will limit boost on an E30, positive would be fine on a mini though.
control seems to be easy in my experience, use a weak twin port actuator to open the vanes under boost, with a MBC to up the boosit if yu need to.
set the low end boost thrshold with the vane stop on the turbo (limit how much they can shut)
use the other side of the actuator with a one way valve to open the vanes at part throttle.
and yes using just the vanes to control boost now.
GaryOS
Member #: 2810
Dublin, Ireland
I couldn't tell you to be honest. I haven't really been as obsessive as usual reading on here over the last 6 months or so which means I have fallen behind a fair bit
GaryOS
Member #: 2810
Dublin, Ireland
Thanks for that Joe. I must admit that I haven't done any research yet so that will help me get my head around what is required.
GaryOS
Member #: 2810
Dublin, Ireland
I took a few measurements today and I have more questions than before I started.
1. When measuring the inducer and exducer diameters do I measure at the narrowest and widest point of the compressor (or turbine) respectively?
2. Is the A in A/R measured at the flange or the cylindrical section of the housing before it changes to the flange shape?
Assuming I measured the inducer and exducer correctly then I have a compressor trim of 50, a turbine trim of 72 and a compressor A/R of .45. I don't know the turbine A/R yet
GaryOS
Member #: 2810
Dublin, Ireland
http://media.photobucket.com/image/gt2056v...56_plotting.gif
I'm just adding this as I'll forget how I found it later
fab
Member #: 100
Parisien Turbo Expert
Paris' suburb
before going furter, you should check that the vane controller finger is outside form the block and not between turbine hsg and block, it will not clear enough to control the vanes.Then if it is right (but I don't think from your pics), check that oil feed is between 20° from straight up.
These late type vnt turbos cannot be rotated as older ones.
Then to control the vanes,don't woory,Joe's right:
you just need an actuator with suck and blow side, as an r5gtt one, make the actuator holder, and adjust the vanes screw to limit overboost, then spend some time to check the right actuator settings.
