Home > General Chat > steering colum swap?
clubby_turbo
Member #: 403
sydney Australia
I have a 78 clubman and im in the process of making a dash for it, i dont realy want to fit switches to the dash so i was wondering if there is a late model steering colum that has whiper motor, headlights and washer bottle switches on it that i could fit? Im doing a new wiring loom aswell so it shouldnt be a problem to wire up.
Cheers. Chris
998 turbo
They're still in the dash on all the late minis IIRC.
You'd probably have to adapt some metro ones to fit if you want all that....
The 97-onwards MPI cars have stalks with all that on, however the splines for the steering wheel are different, so you'll have to either use the MPI steering wheel, or try and get a boss for an aftermarket wheel.
nutter driver
Member #: 47
Not very sunny swanage
you can fit the metro switchgear on fairly easily, its not exactly plug and play, but its very doable....
also stuff from the likes of all the rovers uses similar stuff. rover 25's, later metros etc.
