Home > General Chat > idea: air supply to rear subframe mounted radiator for charge cooler?
Sir Yun
Member #: 1592
Smart Guy!
Hi all.
weird idea..this is the grand idea so far:
BMW 16head GT 1752 turbo clutch mounted with side exit shorty exhaust (bike style). ergo the tunnel under the bottom is not used.
water to air charge cooler. fitted directly to the plenum. (add: that
would be under the bonnet where it belongs..NOT the rear)
but where to stuff the needed radiator?
I would wager a guess that a few heater matixes would suffice coolling wise. i would like to stuff a plenum in the rear subframe and use the now unused space of the tunnel to stuff in an air intake.
does anyone ever try and suck air from the bottom of the car? i know the sides are pretty useless for getting air.
Edited by Sir Yun on 30th Jul, 2009.
andywaller
Member #: 1826
Maldon Essex
I'm going to be putting air ducts in my diffuser to get air into my boot mounted radiator.
not got that far yet but the idea is there.
Mr Joshua
Member #: 1954
Luton Bedfordshire
That title make no sense when you consider the content of your post.
Own the day
OFF WITH HIS HEAD
1972-ANGUS
Member #: 3894
sallys gap. garden of Ireland
On 29th Jul, 2009 joeybaby83 said:
OFF WITH HIS HEAD
*Rofl!*
AWDmoke
Member #: 713
Western Australia
A number of the guys with Starlet conversions run a radiator in the boot floor. An electric fan sucks the air from under the car & out through holes in the boot lid.
On 24th Dec, 2008 Nic said:
best_stig
Member #: 6449
Brisbane, Australia
That could be good. Then get a bodykit around the car and create low pressure under the car. Suck the car onto the road lol.
In boost we trust
Ben H
Member #: 184
Melton Mowbray, Pie Country
Obviously if space is short then the chargcooler with radiators in the back is the obvious route and has been done by many in different cars.
I have been trying to think of a worse place to put an air intake than where you suggest. So far you win. Perhaps under the drivers seat would be worse, but at least it would be dry.
http://www.twin-turbo.co.uk
I think the post is confusing, and a few people have got the wrong end of the stick.
my take is that the air-intake proposed is for cooling to the heater matrix in the boot, rather than the fresh air for the engine. The mention of a plenum in the boot also seem erroneous.
As it goes, taking the air for the rads in the boot using the tunnel seems obvious, and should work better than using the sides of the car.
I would suggest using a thinner rad with a bigger surface area rather than the small thick heter matrix.
AWDmoke
Member #: 713
Western Australia
Use an airconditioner condenser, either automotive or household type.
Cheap, light, the right size & shape, usually aluminium alloy.
Mr Joshua
Member #: 1954
Luton Bedfordshire
*Rofl!*
Own the day
Sir Yun
Member #: 1592
Smart Guy!
Picking up head..*tongue*
yep..
but rather than sticking the radiator in the boot i was thinking of a plenum with the rad in it fitted inside the rear subframe.
the idea that you can sort of ''ram air'' the lot.
i will look into AC condensers.. thanx for the heads up.
1972-ANGUS
Member #: 3894
do you mean intercooler rather than plenum?
I think its more meant to mean a cowling around the radiator to ensure the full flow from the intake goes through the rad?
Maybe...
1972-ANGUS
Member #: 3894
Maybe...
HHHMMMM!!
Maybe.... indeed
The plot thickens....
Would a front mounted rad do just that?
Sir Yun
Member #: 1592
Smart Guy!
jeez.. I must have been on something when I wrote this.
what james_h means .
plenum is just a fancy name for a box.
I need my boot for ..well being a boot.
it is not a drag toy.
I thought a plenum was the opposite of a vacuum.
GaryOS
Member #: 2810
Formally spanner181187
Dublin, Ireland
Not really. A vacuum is a volume free of matter. A plenum is just a volume of above atmospheric pressure. The opposite of a vacum would be a volume which contains all matter.
*head explodes*
On 30th Apr, 2010 Rod S said:
Gary's description is best
As long as you're not planning on taking the air for the engine from under the car, I don't se aproblem then.
Mr Joshua
Member #: 1954
Luton Bedfordshire
Get out! I can tolerate some of the sience speek on here but now you've gone too far *Punch*
*head explodes*
Own the day
GaryOS
Member #: 2810
Dublin, Ireland
haha, I get that reaction surprisingly regularly
*head explodes*
