| Home > General Chat > Good 4 pot calipers. | |||||||
1st Aug, 2009 at 10:22:31pm
I am considering changing to some 4 pot calipers and was wondering which company produce good ones.
![]() 367 Posts Member #: 1643 Senior Member West London |
1st Aug, 2009 at 10:33:26pm
I had KAD 4 pots and rate them very highly! Not had the Minispares ones, nor drove with them, so can't comment.
Lightweight racer coming soon. |
180 Posts Member #: 591 Advanced Member Rugeley, Midlands, England |
4th Aug, 2009 at 05:45:56pm
I have kad ones, expensive yes but quality is second to none. |
4th Aug, 2009 at 05:51:17pm
I've got the Minispares versions. They are very good, but I've not used any other variants, so can't compare. In the 13's at last!.. Just |
4th Aug, 2009 at 06:05:25pm
The Minisport 7.5" ones i have infront of me have got an M10 or M8 bolt in the the caliper with a bleed nipple then in that.
4th Aug, 2009 at 06:10:23pm
the old minispares calipers are good, not the bling machined shiny anodised ones, but the old cast ones
157 Posts Member #: 6496 Advanced Member Somerset |
4th Aug, 2009 at 06:24:34pm
I have just fitted the minisport ones. Braking seems ok, but then again I haven't driven a mini without a servo for ages so will take some getting used to.
On 9th Feb, 2010 joeybaby83 said:
yep, ball in a tube affair |
4th Aug, 2009 at 06:24:35pm
Whoops: double post Edited by Owen on 4th Aug, 2009. On 9th Feb, 2010 joeybaby83 said:
4th Aug, 2009 at 07:09:25pm
am sure tarox do a nice brake setup for 10" wheels.
603 Posts Member #: 1938 Post Whore near Dundee |
4th Aug, 2009 at 10:30:41pm
On 4th Aug, 2009 James_H said:
The Minisport 7.5" ones i have infront of me have got an M10 or M8 bolt in the the caliper with a bleed nipple then in that. Perhaps they have changed the design around the nipple? i havent used them yet, they are just bolted to a set of hubs. They may be for sale soon if you are interested, Discs aswell. the old design didnt have the bolt you mention i dont think. my 7.9 vented setup use the bolt but as there not on the car cant tell you what like they are. |
5th Aug, 2009 at 08:34:58am
Mini spares - Mini spares - Mini Spares
On 17th Feb, 2009 Rob H said:
