| Home > Beginners Tech > bearing needed | |||||||
![]() 736 Posts Member #: 1865 Post Whore Norwich, Norfolk |
3rd Aug, 2009 at 05:52:15pm
i need to order a bearing but i dont know what its called, im sure minispares has them.
Edited by Simon on 3rd Aug, 2009. |
3rd Aug, 2009 at 06:02:35pm
is yours an original turbo box? theyre slightly bigger then the na one
3rd Aug, 2009 at 06:39:31pm
1st motion shaft nose bearing, & yes the Turbo one is bigger than the normal one. So you need to order a Turbo, or standard one depending which housing you have. |
3rd Aug, 2009 at 06:53:39pm
cheers chaps, i believe i need the smaller size.
3rd Aug, 2009 at 07:13:44pm
i can only seem to find one size :S
3rd Aug, 2009 at 07:21:32pm
The turbo type is approx 43mm OD. The standard type is smaller. This should help you identify your casing.
3rd Aug, 2009 at 07:23:49pm
thats the small one,
3rd Aug, 2009 at 08:04:47pm
The price is the giveaway as to which is which... On 17th Nov, 2014 Tom Fenton said:
4th Aug, 2009 at 04:42:46pm
If thats what the inside of your transfer casing looks whats the finished car going to look like Own the day
although my cover is just as clean, a good sloshing or liquid (not spray) gunk and a wire brush on the end of a dremel, comes up a treat
