| Home > Help Needed / General Tech Chat > final drive between a and a+ gearboxes? | |||||||
8th Aug, 2009 at 10:38:05pm
hi, i plan to run a close ratio gearbox from a 1275gt, and am looking at changing the final drive.
9th Aug, 2009 at 07:30:15am
Yes! On 13th Jul, 2012 Ben H said:
9th Aug, 2009 at 10:32:32am
You need the a series transfer case as well as the drop gears are different sizes. On 11th Feb, 2015 robert said:
9th Aug, 2009 at 01:16:37pm
You can buy conversion bearings so you can use the A+ gearbox case or transfer case with an A idler gear On 26th Oct, 2004 TurboDave16v said:
9th Aug, 2009 at 09:23:36pm
how hard are the a series idler cases to get hold of second hand? are they the same for all a series engine, or is the 1275 one specific to the 1275 engine?
9th Aug, 2009 at 11:21:03pm
The transfer housing should, ideally, be considered as part of the gearbox anyway as they are allegedly matched machined as one for the idler gear bearing recesses. In practice I think it makes little difference but the bearing recess in an A housing is certainly a different size to match the A gearbox casing. Availability second hand is I guess, about the same as early gearbox casings as that's what they belong with. I have a couple but I'm intending to use them on A+ gearboxes with the bearing sleeve Sprocket mentions so I can use A drop gears on an A+ box.
Edited by Rod S on 9th Aug, 2009. Schrödinger's cat - so which one am I ??? |
10th Aug, 2009 at 12:45:06am
hi, thanks for the replys. i have had a quick look on mini spares website but cannot find what you hjave described.
10th Aug, 2009 at 01:03:23am
http://www.minispares.com/Product.aspx?ty=...R%20GEAR%20CO... On 26th Oct, 2004 TurboDave16v said:
10th Aug, 2009 at 08:07:52am
I have a spare pre a+ 1275 transfer housing and drops. On 11th Feb, 2015 robert said:
