| Home > Help Needed / General Tech Chat > Petrol smell on full boost -- I can hear it, I can see it --Solved-- | |||||||
11th Aug, 2009 at 02:50:13am
Over the last few months I have been having a smell of petrol when I go on full boost, it started with just a whiff but has got so bad now I'm concerned.. I dont see any sign of a leak in trhe engine bay.
Edited by Turbo Tel on 20th Aug, 2009. website:- http://www.terryhunt.co.uk
11th Aug, 2009 at 06:15:59am
its hard to say, but on full boost mine leaks a little but nothign to worry about! although saaying that JF's throttle spindle leaked when we had our first RR and caught fire |
11th Aug, 2009 at 12:23:31pm
Check your fuel lines. If your not useing the correct spec. Hose ie. the double walled cotton/steel reinforced wall you may find that the pie has degraded with time and has begun leaking.
Own the day
11th Aug, 2009 at 08:17:51pm
I'm using fuel injection hose.. But it did occur to me that a joint could be weak and seeping when the boost rises and the fuel regulator raises with it..
11th Aug, 2009 at 09:11:12pm
Choke seal perhaps? On 19th Jan, 2010 wil_h said:
11th Aug, 2009 at 10:02:08pm
the fuel pressure will obviously rise with boost, maybe the needle valve is being over powered and its coming out breathers or filling the plenum?
11th Aug, 2009 at 11:41:21pm
I used a syringe and raised the pressure, no leaks seen.. Its rubber injector hose.
Edited by Turbo Tel on 11th Aug, 2009. website:- http://www.terryhunt.co.uk
12th Aug, 2009 at 06:02:37pm
12th Aug, 2009 at 08:26:51pm
Not that...
Edited by Turbo Tel on 12th Aug, 2009. website:- http://www.terryhunt.co.uk
12th Aug, 2009 at 08:41:45pm
I wonder if you can get any UV dye, pop some of this in your tank, run up the road to get the fuel smell, then track down the leak with a UV light source? I know that the air con guys use something similar to find ACU leaks.
12th Aug, 2009 at 08:43:05pm
a bit of everything!
12th Aug, 2009 at 08:45:27pm
Ho ho ho, Joe replied to the wrong thread!
12th Aug, 2009 at 09:06:24pm
leaky diaphragm on the dump valve ,letting air/fuel through from the actuation pipe? Medusa + injection = too much torque for the dyno ..https://youtu.be/qg5o0_tJxYM |
12th Aug, 2009 at 09:06:40pm
12th Aug, 2009 at 09:12:56pm
On 12th Aug, 2009 Tom Fenton said:
I wonder if you can get any UV dye, pop some of this in your tank, run up the road to get the fuel smell, then track down the leak with a UV light source? I know that the air con guys use something similar to find ACU leaks. Yes, Must look into that.. I do have a UV dye light and glasses.. I suppose some dye in the tank would not hurt anything?? With all the A/C over here its easy to get UV dye. EDIT:- just found some all in 1 dye thats good for gasoline.. http://www.tracerline.com/dyesforfluids_all-in-one.html And No Dump valve.. I tried a bypass valve at the start of the year but took it off because of this problem... Must have upset something I guess.. Edited by Turbo Tel on 12th Aug, 2009. website:- http://www.terryhunt.co.uk
12th Aug, 2009 at 09:54:37pm
If its a strong enough smell to get you worried i would have thought that it would be after carb IMO.
12th Aug, 2009 at 10:01:17pm
i wonder if it will make y our exhaust glow in the dark lol "Turbo's make torque, and torque makes fun"
![]() 1105 Posts Member #: 1504 Post Whore Westbury, Wiltshire |
12th Aug, 2009 at 10:51:42pm
Terry.
13th Aug, 2009 at 09:51:01am
Or the boost guage itself leaking ? |
13th Aug, 2009 at 12:40:19pm
Put some talcon powder on it or if you can get it NDT dye penitrant developer (talcon powder in a can). Own the day
13th Aug, 2009 at 03:27:56pm
On 12th Aug, 2009 turbominivanman said:
Terry. Does your boost gauge come from the manifold after the carb ? In which case, have you got a split in the gauge line at the back of the gauge in your dash which could be opening up on full boost and giving you a whiff of fuel/air in the cockpit ? Richard. Yes it comes off the manifold but the pshhht sound is coming from outside.. Plus when I remove the bonnet its harder to smell the petrol.. The other thing I thought of was the vacuum takofff for the servo.. what if the one way valve was breaking down?? I guess I'll block it next.. Just ordered some UV dye for fuel systems.. Terry website:- http://www.terryhunt.co.uk
13th Aug, 2009 at 03:31:49pm
On 12th Aug, 2009 joeybaby83 said:
i wonder if it will make y our exhaust glow in the dark lol LOL... I recently had some tests done on my eye which involved a flurescent dye injection.. When I pissed afterwards it was like a yellow highlighter pen colour. I actually turned the light off to see if it glowed!! It didn't :$ Edited by Turbo Tel on 13th Aug, 2009. website:- http://www.terryhunt.co.uk
14th Aug, 2009 at 07:08:53am
On 12th Aug, 2009 mini13 said:
have you blocked off the overboost valve? and have you blocked the overboost safety valve thingy? |
15th Aug, 2009 at 07:49:03pm
have you blocked off the overboost valve? and have you blocked the overboost safety valve thingy? It looked OK.. I have a nut and bolt there with seals.. No sign of any fluids.. Just waiting for the UV dye to arrive, not got much time to play this weekend it being Her indoors's B/day and our Aniversary as well.. website:- http://www.terryhunt.co.uk
16th Aug, 2009 at 08:53:10pm
well had that in my 1380 on full boost it turned out to be blow by paST THE PISTONS AND THE SMELL WAS COMING FROM THE BREATHERS MATE SO MAY NOT BE TO GOOD. always looking for them bigger bunches of bannanas |
was quite funny!
