| Home > Help Needed / General Tech Chat > Alternative turbo placings? | |||||||
9 Posts Member #: 416 Junior Member Tiel, the Netherlands |
28th Nov, 2004 at 08:21:51pm
I've done some reading in the Vizard book. I saw the 7 enterprises turbo kit, and the Janspeed. Both put the turbo elsewhere then the metro turbo set-up. Any other alternatives? I'd like to keep the bulkhead intact, but fit a GT22 turbo (and intercooler and megasuirt'nEDIS EFI). Hugo
28th Nov, 2004 at 09:36:49pm
you can put it wherever you like dude seeing as you'll be making the new manifolds for it anyway. On 20th Oct, 2015 Tom Fenton said:
28th Nov, 2004 at 11:06:00pm
Over the clutch housing is ideal. There is space here, it's away from the carb and the Turbo gets a good cold air feed.
969 Posts Member #: 47 Post Whore Not very sunny swanage |
28th Nov, 2004 at 11:48:48pm
injection is an issue on the a series. do a search for a thread on here explaining the reasons why.....
And on the 7th day........... God created turbochargers! |
28th Nov, 2004 at 11:51:08pm
http://www.turbominis.co.uk/forums/index.php?p=vt&tid=2348
29th Nov, 2004 at 07:06:51pm
Thanks for the replies. I think I'll bolt it to the clutch housing, just have to think of a way to keep the clutch slave cylinder cold....
Hugo
29th Nov, 2004 at 07:36:57pm
The slave cylinder on the Janspeed engine is mounted on the back of he block where the fuel pump hole is. The clutch is operated by a long rod.
29th Nov, 2004 at 10:43:37pm
has anyone considered or done an alternative fuelling method successfully or a 16v head ardon 8 port etc |
30th Nov, 2004 at 03:21:02am
if it doesn't worry you, then you don't fully understand the problem in injecting the A-Series...
![]() 1128 Posts Member #: 142 Post Whore Winchester |
30th Nov, 2004 at 11:30:57am
i'de listen to what dave has to tell you mate, he knows what he's on about concerning injecting the a' series turbo,
30th Nov, 2004 at 05:05:08pm
On 30/11/2004 03:21:02 TurboDave said:
if it doesn't worry you, then you don't fully understand the problem in injecting the A-Series... Megasquirt won't perform miracles just because you built and can map it yourself, the problem is that the carb does a half decent job of supplying fuel, when the engien demands it. EFI always injects the fuel at the same time - or in the A-Series - the WRONG time! D Dear TurboDave, I appriciate your input, though I take offence (mildly...) in your opening statement. You are undoubtebly knowledgable, but there are ways around the problems. As I stated, I will do TBI (throttle body injection) and since MS can do 8 injections per ignition (16 per revolution), I will come very, very close to the performance of a carb. Without the hassle of mechanical alterations to change mixture, and with the addition of programmable ignition. I fully comprehend the siamese port issues, and I don't expect MS'nEDIS to outperform a carb. But it won't be performing any worse either, with the mentioned bonusses. Best regards, Hugo
30th Nov, 2004 at 08:26:41pm
Take offence?????????????
30th Nov, 2004 at 09:02:50pm
OK, offence is maybe too strong, too. What's a mild version of that in English?? Anyway:
Hugo
591 Posts Member #: 360 Stu from Corwall aka Mr Jazz Piano, Love_Machine, kneegrow |
30th Nov, 2004 at 10:46:59pm
I had a chat to a bloke involved in Abingdon ST. he was mucking around with fuel injection on Weslake heads (8 ports) and said that a supercharged one of those was the way to go. For some silly reason (not classes) they built it around a 999 engine. It ate everything for breakfast and destroyed itself every month. I think they were using Tecalamit Jackson FI.
Bugger off, I'm getting there. |
1st Dec, 2004 at 07:02:47pm
Well, to give you gyus an idea there was a story in either Hotrod or Popular HotRodding where they fitted a turbo in a late model Camaro. The real eye opener is that it was mounted where the rear muffler (silencer in UK) was located. Just get rid of the muffler, fit the turbo there, suspend it, run a long tube back to engine, fix, oil feed and return with a pump and off they went. They ran wild boost setting of 7 psi max and quoted a lot of extra power. I KID YOU NOT !!!! |
2nd Dec, 2004 at 10:28:28pm
no news about 16v or alternate heads? |
3rd Dec, 2004 at 06:33:03pm
there is a BMW motorcycle head for sale in german ebay... |
3rd Dec, 2004 at 06:51:12pm
link?
10th Dec, 2004 at 11:06:24am
Phil where is the oil drain on the Janspeed setup?
AlexF |
10th Dec, 2004 at 02:27:40pm
11th Dec, 2004 at 05:29:11pm
cheers phil AlexF |
12th Dec, 2004 at 05:33:04pm
With regards to funny heads, I have heard that the K1, K1000 bike heads valves are too small. Much smaller than the KAD road head. I suppose that is why Bruno Raoille (sp?) did a 970 engine with one on. I think he was one of the first to do it. I have heard people using Corsa 1.2 heads (rumoured). Minispares have a funny OHC thing by Howley which according to Keith "Is in a container somewhere".
13th Dec, 2004 at 07:16:19am
IIRC the valves are 26 mm intake, 20 or 21 mm exhaust (I believe KAD valves are about the same). Small yes, but there are 2 each. So total valve area exceeds that of any big valve head. Add that to smallish ports and there is a good recipe for a fast flowing induction. If you need exact dimensions I can measure the valves of my K1100 head.
