| Home > Help Needed / General Tech Chat > Gearbox to block splitting | |||||||
80 Posts Member #: 6234 Retard & Spaz Yeovil, Zummerset |
12th Aug, 2009 at 11:49:00am
um, i have a small problem, my gearbox has blown but i am going to put s/c in the car, however the way my garage is the engine hoist is a pain in the ass to get to, so can i split the block and gearbox in situ? odviosly taking off exhaust manifold and inlet etc Currently building the new engine - 1312 t25 a series! |
203 Posts Member #: 1734 Senior Member Lancaster |
12th Aug, 2009 at 11:52:11am
yes you can. I did this once when I didnt have a hoist. its a bit time consuming though. Edited by manifold on 12th Aug, 2009. |
![]() 453 Posts Member #: 6449 Senior Member Brisbane, Australia |
12th Aug, 2009 at 11:58:48am
Be a bit of a pain in the arse really. Got to get the flywheel off. So if you have inner guards itd be a tight squeeze for a puller. In boost we trust |
12th Aug, 2009 at 12:04:13pm
To be honest, its probably going to be less hassle to just dig out the hoist and pull the engine. On 7th Oct, 2010 5haneJ said:
12th Aug, 2009 at 12:09:30pm
If you cant get the hoist out, 2 strong lads can lift it out manually
I seriously doubt it! |
12th Aug, 2009 at 12:24:14pm
On 12th Aug, 2009 paul wiginton said:
If you cant get the hoist out, 2 strong lads can lift it out manually Paul Err no...With a removeable front maybe... On 13th Jul, 2012 Ben H said:
12th Aug, 2009 at 12:26:53pm
WTF you on about? I done it loads of times.
12th Aug, 2009 at 12:28:31pm
I've lifted many engines out of minis when I used to work at a mini centre and "doom" them, with a decent length of scaff bar and the guy I worked with we just used to rope the bar to the engine then shoulder it and hoik them out.
12th Aug, 2009 at 12:33:16pm
When I worked in the trade we often dropped complete subframe with the engine and then lifted the engine/trans out.Two people can easily lift the body away and prop it up on a couple of oil drums.Plenty of access then ! |
12th Aug, 2009 at 12:55:09pm
12th Aug, 2009 at 12:58:22pm
On 12th Aug, 2009 tadge44 said:
When I worked in the trade we often dropped complete subframe with the engine and then lifted the engine/trans out.Two people can easily lift the body away and prop it up on a couple of oil drums.Plenty of access then ! Like this?
12th Aug, 2009 at 01:38:49pm
If your big enough you can do it your self!
Own the day
![]() 2054 Posts Member #: 452 Post Whore Chester, UK |
12th Aug, 2009 at 01:49:18pm
supermottolee and myself have removed an engine however when putting it back in we had an extra person as it was easier.
12th Aug, 2009 at 02:15:07pm
If you cant get the hoist out, 2 strong lads can lift it out manually Paul Err no...With a removeable front maybe... 2 guys if u have a steel front, 1 can do it with a removable front :) Yes i moved to the darkside |
12th Aug, 2009 at 05:32:05pm
Evidently taking engines out when your stood on ice is much more difficult than concrete On 12th Aug, 2009 Vegard said: On 12th Aug, 2009 paul wiginton said:
