| Home > Help Needed / General Tech Chat > harness mounts | |||||||
12th Aug, 2009 at 09:25:53pm
Going to be fitting 2 harness mounts into the back seat upright for my 4pt harness just wondered if they needed to be welded in or just being bolted through would do the same job? 99% sure they've gotta be welded but thought i'd check first.
Edited by Nick on 12th Aug, 2009. On 20th Oct, 2015 Tom Fenton said:
12th Aug, 2009 at 09:32:05pm
mine are bolted in and i use the same plates as above.
12th Aug, 2009 at 09:41:56pm
I use the same plates, but on the seat back put a strengthening plate, all welded up. http://www.twin-turbo.co.uk
12th Aug, 2009 at 09:46:39pm
They are the plates we use when we fit seats in VW Transporters and the like at work.
603 Posts Member #: 1938 Post Whore near Dundee |
13th Aug, 2009 at 12:57:59am
after having a nosey at mikeraces's mini at IMM i quite like the way he has done it but im not sure how he has braced it.
13th Aug, 2009 at 01:10:50am
IS THAT AN EXHAUST HANGER????????
13th Aug, 2009 at 07:53:16am
Yes, that looks neat, but I wouldn't be trusting my life with it.
Edited by wil_h on 13th Aug, 2009. Fastest 998 mini in the world? 13.05 1/4 mile 106mph
13th Aug, 2009 at 07:56:54am
Get the proper FIA nuts/brackets instead, and weld them up. On 13th Jul, 2012 Ben H said:
13th Aug, 2009 at 05:30:16pm
planning on using the std mounts at the front, seat will be mounted off the front of the crossmember cos i've only got stumpy little legs so won't be too far back.
14th Aug, 2009 at 10:46:41am
On 13th Aug, 2009 Nick said:
planning on using the std mounts at the front, seat will be mounted off the front of the crossmember cos i've only got stumpy little legs so won't be too far back. Looks like i'll weld em in then to be safe. Get back to the circus pigmy. |
969 Posts Member #: 47 Post Whore Not very sunny swanage |
14th Aug, 2009 at 08:53:38pm
i REALLY dont like the idea of harnesses in that sort of area, i just cant see why on earth anybody with a cage wouldn't use a proper harness bar. If you must put harnesses there, you really need to look at seriously reinforcing the bulkhead as its really not designed for that sort of load.....
And on the 7th day........... God created turbochargers! |
