Home > Introduce Yourself > Hi everyone!!
nuukuus
Member #: 6857
Lieto / Finland
I'm from Finland and I have here Cabriolet with supercharger and nitrous. Maybe someone has seen my Cabriolet IMM 2009.
You find some pictures of my Minis from this address
http://mikaj.1g.fi/kuvat/Jani/
1399cc, Eaton M45 supercharger, N2O system, compression ratio 9.23:1, boost pressure 0,8bar/11.6psi.
http://www.garaget.org/?car=176816
Hi there.
Let's have some pic's and a spec in 'Show us yours'
Hi!
nuukuus
Member #: 6857
Lieto / Finland
Hi just klik that web address link, now it should be ok..
hi and a warm welcome
nuukuus
Member #: 6857
Lieto / Finland
Here is some spec.
Engine: 1399cc, Roller rockers, Steel valves, Cometic head gasket, Accralite pistons, Lightened Cooper S rods, MED Engineering latest specs 82,3mm crankshaft, Piper 285 scatter billet camshaft, Adjustable timing gear, Mini Spares ultra-light flywheel and back plate, Grey pressure plate, AP Racing clutch plate, Eaton M45 supercharger, Finn turbo cooler, N2O system, compression ratio 9.13:1, boost pressure 0,9bar/13.05psi.
Gearbox: Cooper S ratios,
1:1 Straight cut drop gears, Swiftune Engineering torsen type differential lock, 3.1:1 final drive
Engine adjustment: Haltech E8 ecu, Jenvey throttle body with 2 injectors.
Color: Night fire red, House of Kolor mystic gold pearl.
Brakes&Suspension: Kad K4 brake kit 10,4” disc, Super finn rear drums,
AVO 2 way adjustable shocks.
Edited by nuukuus on 18th Sep, 2009.
stefaz
Member #: 1656
stoke-on-trent
welcome
turbominivanman
Member #: 1504
Westbury, Wiltshire
Hello and welcome.
It was very interesting talking to you at the IMM on Saturday when you were showing your car. It was a crowd puller all day.
If you recall, we got talking about your chain driven alternator which I've not seen before.
I think you've done a great job on your car and congratulations for driving it so far to the show.
Hope you enjoy being a member on TurboMinis.
Richard.
nuukuus
Member #: 6857
Lieto / Finland
Hi Richard!
Well you was not only who wondering that solution.
There is eawen some people how don't believe that tooth belt not hold there, but i try it so many differend way and that is really only version which hold there.
JAni
welcome
Oli
Member #: 1910
Wilts
Welcome aboard !
Mr Joshua
Member #: 1954
Luton Bedfordshire
Welcome
Own the day
Welcome *happy*
