Home > Show Us Yours! > VW Passat Intercooler
akirch
Member #: 399
Austria
VW-Passat-Intercooler in my Mini:
http://www.8ung.at/pmf
Edited by AlexB on 4th Jan, 2005.
http://www.minifreunde.at
Zeemax Power
Member #: 393
Oulton Park
does it draw lots of air there
http://www.Zeemax.com
AlexF2003
Member #: 80
AFRacing LTD
Newbury, Berks
why the air filter behind everything rather than in front of the grill?
alex
AlexF
b12
Member #: 247
Kent/Surrey Borders
Home made plenum ??
TurboLessTosser
gregor
Member #: 98
Slovenia
Hi Arkich,
it is interesting to see your intercooler position. did you measure the temperature of outlet air?
perhapse you will remember.... we spoke together on mini meeting in Czech republic this september. i have a yellow turbo mini from Slovenia.
Gregor
very neat. I was trying to work out how you managed to put the intercooling pipe-work wher you did.... Then I realised it's left hand drive... Durr
Wil
akirch
Member #: 399
Austria
Hello,
Yes, the plenum is home made. The three holes to the carburetor are missing at this picture:
For the airfilter i can't find a other place. The filter is too big. *frown*
http://www.8ung.at/pmf/updates2004/1127_fertig/fertig.htm
http://www.8ung.at/pmf/updates2004/1118_ll...u/llkeinbau.htm
Gregor, i have a photo of your yellow Mini at my homepage:
Have a nice day!
Andreas
gregor
Member #: 98
Slovenia
hi Andreas,
i like your page but i should learn german lenguage to understand it.
he,he, it is first time that i see my mini without bonnet on the web.
Gregor
Edited by gregor on 2nd Dec, 2004.
akirch
Member #: 399
Austria
Bad holidays. *frown* Cylinder head gasket was gone at the side of the clutch:
And i dont know why. The temperature was OK. Maybe wrong ingnition, or the cylinderhead-nuts were not enough screwed on, or...
I think it was pinking (or knocking or however this is called in english).
The new year starts perfect! *oh well*
Enough work. It seem's like a never ending story...
AlexF2003
Member #: 80
AFRacing LTD
Newbury, Berks
pinking will make a head gasket go..
what type of head gasket was it?
Payen BK450 (the black sticky one)?
alex
AlexF
akirch
Member #: 399
Austria
No, it was an other gasket. Now i will take the BK450 and an other head that makes lower compression. Maybe the boost was to much with the standard head...
would you be able to measure the thickness of the intercooler for me please? ive seen one of these units and i think it could be ideal for me
akirch
Member #: 399
Austria
greypride,
The dimensions are 25x18x6cm (only the cooling web - without plastic connections). The external diameter of the connections are 54mm. I reduced to 48mm pipes...
fantastic, thanks
