| Home > General Chat > Eletric Fan | |||||||
329 Posts Member #: 3193 Senior Member Torbay, Devon |
26th Aug, 2009 at 10:43:11am
Hi
26th Aug, 2009 at 11:20:10am
I bought my fan from ebay. I think its a kenlow and was about £40, its a 9" fan (same as MPI use). More than up to the job and verycompact. https://www.facebook.com/pages/Fusion-Fabri..._homepage_panel
26th Aug, 2009 at 11:24:56am
Actually mine is a spal fan similar to this.
26th Aug, 2009 at 11:28:14am
I had a metro rad on my old clubman with a 9" kenlowe jap copy running from the standard metro switch. worked a treat. On 11th Feb, 2015 robert said:
26th Aug, 2009 at 11:32:51am
Hi
26th Aug, 2009 at 11:40:28am
just make sure it is blowing the correct direction |
26th Aug, 2009 at 12:21:06pm
They generally sell two different versions suck or blow, so you can either mount it from the front or the rear. https://www.facebook.com/pages/Fusion-Fabri..._homepage_panel
![]() 2102 Posts Member #: 432 Post Whore Swindon |
26th Aug, 2009 at 01:30:12pm
the fan switch you talk of, i assume you mean something like this?
26th Aug, 2009 at 01:34:14pm
On 26th Aug, 2009 Mini_Andy said:
the fan switch you talk of, i assume you mean something like this? http://cgi.ebay.co.uk/NEW-LUCAS-RADIATOR-F...id=p3286.c0.m14 where do you fit it? On 11th Feb, 2015 robert said:
26th Aug, 2009 at 04:46:59pm
are you getting rid of the normal fan? if so im not sure JUST an electric 9" fan would be upto the job seeing as they arnt designed for constant use, only for a quick burst of cool air, usually rads are mounted on the front of cars so they get the cool air going through them, if you notice the electic fans only come on when in traffic etc.... so unless its a front mounted rad then i would not suggest getting rid of the normal fan aswell :)
Edited by Johnny on 26th Aug, 2009. |
26th Aug, 2009 at 05:34:40pm
i have a 9 or10" sat in my garage has the reversable blade, tripac iirc
26th Aug, 2009 at 06:08:45pm
Keith Timpson is running an electric fan without the original fan with no problems. There should be sufficient flow through the rad when driving, even on a side mount.
On 26th Aug, 2009 Johnny said:
are you getting rid of the normal fan? if so im not sure JUST an electric 9" fan would be upto the job seeing as they arnt designed for constant use, only for a quick burst of cool air, usually rads are mounted on the front of cars so they get the cool air going through them, if you notice the electic fans only come on when in traffic etc.... so unless its a front mounted rad then i would not suggest getting rid of the normal fan aswell :) I was going too, but then i got an ear full! So i decided to go for the 4 blade and not have the electric one and mines fine on heat :) |
26th Aug, 2009 at 06:20:54pm
i suppose so but with mine there isnt much flow to the rad as i have the intercooler in the way :( |
26th Aug, 2009 at 06:32:58pm
are you getting rid of the normal fan? if so im not sure JUST an electric 9" fan would be upto the job seeing as they arnt designed for constant use, only for a quick burst of cool air, usually rads are mounted on the front of cars so they get the cool air going through them, if you notice the electic fans only come on when in traffic etc.... so unless its a front mounted rad then i would not suggest getting rid of the normal fan aswell :) I was going too, but then i got an ear full! So i decided to go for the 4 blade and not have the electric one and mines fine on heat :) I'm with Johnny here - an electric fan will not be enough. The mechanical one is there for reason and that is the cooling is not enough without one. If your car cools okay without one it hasn't got enough power! On 5th Sep, 2011 Vegard said:
26th Aug, 2009 at 06:46:18pm
On 26th Aug, 2009 jonb_5 said:
Also should i be looking for it to sit inside the rad (engine side) or outside the inner wing? Depends on the fan, some suck, some blow. Isambard Kingdom Brunel said:
26th Aug, 2009 at 06:50:28pm
Some suck and blow, depending in which way the blade is fitted and the rotation is reversed On 26th Oct, 2004 TurboDave16v said:
26th Aug, 2009 at 09:13:17pm
if anything you want, good flow to the fan if its blowing so that its blowing cool air into the rad for better cooling since you wont have a normal fan... second if its sucking air it will over heat quite quickly in my opinion.. aparently the 9inch fans diddnt do squat for cooling on the Mpi`s? |
26th Aug, 2009 at 10:30:18pm
i have a front mounted rad and an electric fan mounted behind (so sucking) i have had it overheat once, on the way back from Avon, it was a really hot day and i was sitting in traffic. Other than that its been fine. |
27th Aug, 2009 at 07:59:06am
On 26th Aug, 2009 Sprocket said:
Some suck and blow, depending in which way the blade is fitted and the rotation is reversed ![]() Is that the 6,9" one?? On 13th Jul, 2012 Ben H said:
27th Aug, 2009 at 09:10:28am
whether the fan is blowing or sucking should make no difference to the air it is moving through the radiator - noted on the position of the IC though. Look at the number of moderns with the fans mounted on the enginbe side of the front mounted rads- if the air is being pushed though the rad its going to counter-act with the air being pushed through from the forward motion of the car?
![]() 2054 Posts Member #: 452 Post Whore Chester, UK |
27th Aug, 2009 at 10:14:24am
i tried running my old mini with an electric fan only (even though the plastic one never failed me with a 2 core rad) it didnt work after 1 week of driving i feared traffic like no man should fear traffic.....needless to say its in a box in the garage.
Edited by t@z on 27th Aug, 2009. |
27th Aug, 2009 at 10:23:22am
My electric fan on the side rad with no mechanical fan works just fine, no issues in years. This is a full race n/a dont know if its enough for turbo motors though
I seriously doubt it! |
27th Aug, 2009 at 10:28:52am
If you put a lecy one under the wing you will need to make a bit of a shroud to seal off between the rad and the inner wing. I haven't done this on mine yet and I know I'm drawing a lot of air around the rad and not through it. On 7th Nov, 2008 Nic said:
444 Posts Member #: 2885 Senior Member |
28th Aug, 2009 at 12:40:57am
A fan to radiator cowling is definately mandatory. At least the fan affixed directly to the radiator, neccesitating some inner wing vent removal, sucking preferably into the low pressure innerwing.
Edited by hario on 28th Aug, 2009. |
