| Home > Help Needed / General Tech Chat > pushrod problem | |||||||
61 Posts Member #: 1885 Advanced Member somewhere |
30th Aug, 2009 at 09:33:22pm
hey
30th Aug, 2009 at 09:51:07pm
when you dropped the pushrods back down there holes they shopuld have all been withing 1/4" of each other sticking out of the top of the head,
30th Aug, 2009 at 09:51:17pm
On 30th Aug, 2009 danw said:
just done the head gasket on my thou, and a couple of the pushrods were higher and lower than the rest. the higher one was an inch and half higher than the rest and the lower rod was 5-10mm lower. I thought that was perfectly normal due to cam lobes. Isambard Kingdom Brunel said:
30th Aug, 2009 at 10:03:15pm
the head fitted on okay, but obviously the rockers didnt, due to the rod being so high up above the head.
31st Aug, 2009 at 05:40:44am
An inch and a half ? Thats some high lift cam you have there. |
31st Aug, 2009 at 08:14:22am
31st Aug, 2009 at 08:27:10pm
it appeared that the cam followers had come out and fallen over, so when the rods were being put in the holes, they were sitting on the sides of the followers |
31st Aug, 2009 at 09:03:18pm
On 31st Aug, 2009 danw said:
it appeared that the cam followers had come out and fallen over, so when the rods were being put in the holes, they were sitting on the sides of the followers before you pull the push rods out always give them a few twists and a wiggle to free them off the followers. the oil sort of holds them together and when you lift the push rod out it pulls the follower up as well. no longer a series, but still 1.3 turbo.
1st Sep, 2009 at 01:32:52pm
yeah i know that now, didnt realise when i took them out >_< |
