Home > Technical Chat > internal linkage
Nick
Member #: 154
Midlands
after missing out on iains internal linkage i'm thinking about making my own.
Has anyone tried using something like these for the joints?
http://cgi.ebay.co.uk/Ford-Fiesta-Ka-Steer...id=p3286.c0.m14
Just trying to be cheap really cos i know the proper ones are pricey from demon tweeks.
I used these
http://uk.rs-online.com/web/search/searchB...oduct&R=2645368
Not as cheap though
TBH the Ka things would probably be fine, I presumed it would be able to take the forces involved, and have enough angles of movement
Edited by Nic on 1st Sep, 2009.
hope so being as they usually connect to the steering*happy*
personally i am going to use modified socket set uj's, ive hear they wont be able to take the pull push movement but have not seen any one complain they broke it, :) not on the road yet like so cant comment my self
its not breaking them thats the problem, its having accurate movement that is.
They're so awkward to get adjusted right i think any movement in the joints will cause gear selection problems.
I'm sure i've heard that people using socket ones haven't been sucessful.
Edited by iain on 1st Sep, 2009.
Socket UJ's are not true UJ's as the pivot centers are offset causing non uniform drive transmission, and are susceptable to unwanted lateral movement.
Do it once, do it right *wink*
thinking about it sprock + iain u are right ill be having a rethink :)
SidewaysGTM
Member #: 5022
Oxford, Kings Lynn, Pod, Pub.
Socket Ujs dont work
shattered on the first movemnt of the lever, I wondered if they would work myself. they were 3/8 ones.
West
Got A GTM With A Honda In the Back, and huge Nitrous bottle where the passenger seat should be when racing!
On 19th Oct, 2009 Nic said:
Ill donate to the cause if you can make it do wheelies!!
mini93
Member #: 2017
Warwick.
whats the diameter of the shaft? just looking other places for UJ's (hoping to be cheaper than nic's place) and there obviously listing quite a few OD's and if i weld the UJ in i want a matching size
David.
no need to weld dave, just use pins...
Uhmmmm bargain....
http://www.demon-tweeks.co.uk/products/Pro...&pcode=R/PRTUJ1
1/2" alluminium one...
mini93
Member #: 2017
Warwick.
would i need a UJ with a centre bore then? for the shaft to sit in then pin into place?
David.
On 2nd Sep, 2009 James_H said:
Uhmmmm bargain....
LOL
surely a snap-on one would be good enough
just because its snap on doenst mean its any better than the rest, all it means is its good for the job it was designed for, i.e. not changing gears! lol!
end of the day, when building turbo minis, if you going to the lengths of putting the gear change inside its not the largest amount of money you'll ever spend!
you dont get something for nothing
Uhmmmm bargain....
This is what is used on mine, expensive yes, but I've never had problems in 5 years of using it.
A can tell you first hand that a snap on socket has plenty of movement! no good!
I would love to use the racetech ones in mine when i do it, and also possible in the steering column, just not sure i could be prepared to stump up that much on a few UJ's.
Although i don't doubt that they are not worth in, as i bet they are quality items.
those are what i used too, i found them on ebay as 'helicopter joint' slightly cheaper than DT
Uhmmmm bargain....
jim, any chance you could get some pics up of your one?
cheers
I'll try to take some tonight, but it's the same one as above
have a look in minimag this months page 70 the gear linkage in there is a socket set uj and socket set extension bar *happy* and the guy says it jumps out of gear all the time *tongue*
Timinichelsea
Member #: 479
KAD sell some decent UJ's for just under £40 each. seem cheaper then the demon tweeks ones.
or similar try these: http://www.cbsonline.co.uk/gear-linkage-un...t-ujg-922-p.asp damn good website for loads of kit car stuff which can be used on minis
The ones on that site as with all the other sites that sell these joints are unfortunatly nothing more than generic machine drive UJs.
Now theres nothing wrong with them and i myself use and sell these , but its the big sell bullshit that winds me up, the " our jonts have this and our joints have that",
when in fact they simply buy them in and ship them out + 50 % markup,
nothing wrong with that either ,
also they claim to leave them blank for you the poor mug to have to fooking modify to fit because the twats can't be arsed to supply different bores for locating, lazy nobs/.
carl
You're awfully cynical Carl *hehe!*
Edited by Sprocket on 3rd Sep, 2009.
Tell me i'm wrong,lol.
hario
Member #: 2885
Selector shaft is 1/2" IIRC and steering column universal joints will definately be upto the job! They're about 2" wide FFS and designed to withstand wear otherwise every new car would fail the MOT on column play..
gregh55
Member #: 3636
herefordshire
im going to be building an internal linkage soon, how many UJ's will i need?
cheers
