Home > Technical Chat > oil pressure
sprint1380
Member #: 6876
Burton-on-Trent
Through running the mini on the road and especially at santa pod, i noticed that the oil pressure was running off the scale on my smiths guage.
on idel (when warm) the pressure sits at 45-50psi. When reving high (6000-7500rpm) the oil pressure guage bounces like mad at 100psi, so have no idea what the actual pressure is!
Whilst on the rolling road, the car decided to blow the sump gasket, only about an inch at the front of the engine. Could this be due to the over pressure?
Any advice on safe pressures? and possible ideas on cures?
Thanks, Sam
104.7bhp NA
14.36 1/4 mile
5.3sec 0-60
first of all id try another known good gauge because 45-50 psi warm seems way to high and if it is topping out at about 100psi it sounds like your oil pressure release valve is either sticking or set too strong, the maximum oil pressure can be lowered with the oil release valve but the hot running temp cannot be lowered that is down to the internal clearances in stuff like the bearings and the flow rate of the oil pump
is it oil pressure releaf valve or oil pressure release valve? *happy*
the sump gasket is likely to be a coincidence or it not being bolted on tight enough as there should be little or no pressure in the sup or 'gearbox'
sprint1380
Member #: 6876
Burton-on-Trent
ok thanks. il try another oil guage first, but were's the releaf/release valve situated? Ive never touched it before! lol
104.7bhp NA
14.36 1/4 mile
5.3sec 0-60
hang on ive got an idea...
*happy* runs to find a pic *tongue*
*happy*
sprint1380
Member #: 6876
Burton-on-Trent
lol thanks alot pal. should be able to sort it out now.
104.7bhp NA
14.36 1/4 mile
5.3sec 0-60
no probs, you can get things like these to make adjusting it easyer *wink*
http://www.minispares.com/Product.aspx?ty=...EGULATOR%20KI...
sprint1380
Member #: 6876
Burton-on-Trent
would you adam and eve it! ive just been looking at them. Another option i could i try if the pressure drops too low on idel, is an oil cooler or different oil. il try the guage first then go for an adjuster.
104.7bhp NA
14.36 1/4 mile
5.3sec 0-60
High oil pressure will not cause blown gaskets.
sprint1380
Member #: 6876
Burton-on-Trent
just thought that the pressure build up could have pushed the gasket. Oil does bubble out of the missing gasket.
104.7bhp NA
14.36 1/4 mile
5.3sec 0-60
when the engines running, crack off the union on the back of the guage, and bleed any trapped air out
this will cause your guage to bounce about
sprint1380
Member #: 6876
Burton-on-Trent
il try that, if i remember correctly, i didnt bleed the pipe when i fitted it. *blush*
104.7bhp NA
14.36 1/4 mile
5.3sec 0-60
i've never bled an oil pressure gauge yet.
sprint1380 (i've forgotten your name already, is it sam?)
i will give you some good sealant for the gearbox seal if i can find a spare tube when you get the hubs. its called wellseal and its awesome stuff for that join.
sprint1380
Member #: 6876
Burton-on-Trent
mint! thanks alot peeps.
104.7bhp NA
14.36 1/4 mile
5.3sec 0-60
Mr Joshua
Member #: 1954
Luton Bedfordshire
Its a pressure reducing valve. relief/ release valves are fitted to allow flow around an area or component liable to block. a pressure reducing or maintaining valve metres the flow to return to hold the pressure at a set value regardless of flow volume
Own the day
