| Home > Help Needed / General Tech Chat > Gearbox to Block Bolts | |||||||
![]() 736 Posts Member #: 1865 Post Whore Norwich, Norfolk |
3rd Sep, 2009 at 08:52:17pm
After losing my rag with the search function and the odd thread I did find not seeming to be conclusive I thought I would get the old camera out.
3rd Sep, 2009 at 08:56:22pm
Nice crank and rods!! On 13th Jul, 2012 Ben H said:
3rd Sep, 2009 at 08:58:34pm
PM TurboDave. He'll send you a set of hardened allen bolts for not a lot of money.
3rd Sep, 2009 at 09:00:01pm
PM TurboDave I seriously doubt it! |
3rd Sep, 2009 at 09:07:37pm
TurboDave it is then, thanks! |
3rd Sep, 2009 at 09:11:39pm
Are you being sarcastic,lol
On 3rd Sep, 2009 Vegard said:
Nice crank and rods!! |
4th Sep, 2009 at 08:22:25am
Allen heads there.. Don't get me started. You've already got the best of the best. 1/4UNF 3/8 AF bolts. The best!
Edited by Vegard on 4th Sep, 2009. On 13th Jul, 2012 Ben H said:
4th Sep, 2009 at 08:57:48am
Two of them, the ones above the diff casing, are usually studs and nuts as the proximity of the diff casing stops the right length bolt from going in.
4th Sep, 2009 at 10:17:33am
i use allen head bolts, unbrako ones and they work a treat!
4th Sep, 2009 at 10:31:58am
https://minispares.com/Html/AKM/AKM_PDF/03_..._Gear_Train.pdf |
4th Sep, 2009 at 10:38:08am
That looks really usefull Gav. Might have to make a reference copy.... On 11th Feb, 2015 robert said:
4th Sep, 2009 at 11:02:00am
We spent months on it, will move it to the homepage shortly so it's easier to find. |
4th Sep, 2009 at 01:05:54pm
There is no problem getting socket cap screw head bolts above the diff casing. A cut-down allen key makes life easier however!
On 3rd Sep, 2009 ZeroT said: I found 3 short and 1 long one which fit, I think they are the right ones.
![]() 966 Posts Member #: 358 Post Whore Snetterton, Norfolk |
4th Sep, 2009 at 01:27:31pm
Or if you're feeling flush you can buy the short ended allen keys from snap on for about £20 a set. I found them real easy on mine. |
4th Sep, 2009 at 01:36:24pm
On 4th Sep, 2009 TurboDave said:
There is no problem getting socket cap screw head bolts above the diff casing. A cut-down allen key makes life easier however! Vegard, He doesn't have them already: On 3rd Sep, 2009 ZeroT said: I found 3 short and 1 long one which fit, I think they are the right ones. When you find a cut down allen key with a ratchet on it I'd agree
4th Sep, 2009 at 02:04:22pm
That's easy - the cut off bit of the allen key and a ratchet spanner of the same size. |
4th Sep, 2009 at 02:10:10pm
On 4th Sep, 2009 Rod S said:
Two of them, the ones above the diff casing, are usually studs and nuts as the proximity of the diff casing stops the right length bolt from going in. Also, you're missing one in your photo - the dowel at the top left is hollow - a nut and bolt goes through it with large thick washers, one is a special shape. I thought that about the studs & nuts, i've got another block here that has those 2 studs but this one doesnt. Well spotted for the longer bolt thru the dowel, thats included in TurboDaves kit :) |
4th Sep, 2009 at 06:17:44pm
i use a ractchet spanner and allen bit adaptor that came with it.
4th Sep, 2009 at 06:33:24pm
Looking at mine more closely I'm now thinking the two studs/nuts are a throwback to the magic wand / remote boxes where access was even worse.
4th Sep, 2009 at 06:54:26pm
The PDF gavin posted is not 100% accurate though - it doesn't show the 5/16 bolts in the diff housing... On 17th Nov, 2014 Tom Fenton said:
5th Sep, 2009 at 10:16:15am
On 4th Sep, 2009 graemec said:
That's easy - the cut off bit of the allen key and a ratchet spanner of the same size. Then, what's the point? Spite? I can relate to that :) On 13th Jul, 2012 Ben H said:
5th Sep, 2009 at 10:59:12am
I use MS24665-8 bi-hex bolts, the head takes a 5/16 socket.
Own the day
