| Home > Technical Chat > blocking off the water ways, drydeck | |||||||
5th Sep, 2009 at 05:57:39pm
both my head and block are going to be skimmed when they got to my machine shop so i might aswell dry deck the engine now rather than later.
Yes i moved to the darkside |
157 Posts Member #: 6496 Advanced Member Somerset |
6th Sep, 2009 at 01:30:55pm
How would you "normally" do it?
On 9th Feb, 2010 joeybaby83 said:
yep, ball in a tube affair |
![]() 720 Posts Member #: 2588 Post Whore Pretoria South Africa |
6th Sep, 2009 at 01:49:59pm
Normally brass plugs are used (I think) similar to the ones use on the head. "So wat we gonna do tonight Brain?"
6th Sep, 2009 at 01:56:12pm
6th Sep, 2009 at 06:55:58pm
Threaded taper plugs and loctite high stremgth retainer, they will never come out On 26th Oct, 2004 TurboDave16v said:
444 Posts Member #: 2885 Senior Member |
7th Sep, 2009 at 12:30:38am
BSPT allen grub screw things, I thiink Locktite do high temp hydraulic stuff.. |
7th Sep, 2009 at 09:34:59pm
I just tapped mine & used grub screws with loctite, easy & saves having the block skimmed. |
7th Sep, 2009 at 10:54:15pm
drill and tap 1/4" BSP use short taperd hex plugs lock tight like the guys state
