Home > General Chat > Mk2 KAD quickshift?
ccharlie6
Member #: 230
has anyone got one of these new redesigned quickshifts from KAD yet? i was toying with the idea of getting a quickshift and this new one has just come and sounds pretty good especially the no lift up for reverse feature.
any views?
Nick
Member #: 154
Midlands
i had a play with one at MITP, they feel really nice. not cheap tho but i still reckon i'll end up getting one.
SumpNut
Member #: 28
How much money do these go for?
ccharlie6
Member #: 230
?85 i believe. they look the absolute nuts
http://www.kad-uk.com/accessories.htm
Skinns46
Member #: 165
Cambridge
Yes....they look good but have you ever driven a mini with one fitted? I suggest you do that befor buying.
http://photobucket.com/albums/y139/Skinns46/
I have in the past made my own quickshift simply by shortening the std gearlever length a bit. OK not as flash as the KAD one but the same effect for no money. If you are tall like me then you will have no problems.
Also removing the reverse lock is easy, take the screw on plate off the bottom of the gear selector remote under the car, and grind the sticking up "shark fin" off, hey presto no reverse lock.
adam1330
Member #: 238
essex
yeah i agree with 'skinns46' they do take some getting used to! i kept missing gears and not being able to find the gear!
o.k now though- wouldnt go back to a normal gear change.
clubman_dan
Member #: 142
Winchester
i have the new one and as it says above it takes some getting used to, especially between 2nd and 3rd, but once your used to it, its good,
it feels nice and tight (oh errr..)
i reccomend it
DAN :)
mini6r4
Member #: 426
Maidstone, Kent
just seen these for ?30 plus the dreaded at minisport
www.mini-roadster.741.com
Roadster conversion kits on the way!
clubman_dan
Member #: 142
Winchester
that will be the old one, the new ones are apparantley better as there's no need to butcher the old gearstick and you get a cool gear knob and reverse lift collar
mini6r4
Member #: 426
Maidstone, Kent
i thought that, but they have it advertised as 'the new version' and the picture shows the new lever
get one then. if its not the same as in the pic have a bit of a complain and say ul say the goods arent as described.
