| Home > Help Needed / General Tech Chat > Head gasket blown after extended hot running- should I be worried? | |||||||
![]() 667 Posts Member #: 5232 Post Whore basingstoke |
16th Sep, 2009 at 08:33:45am
Hi guys. just after a bit of advice on this one:
Mr. Prawn, the friendly Crustacean- slowly making steps towards forced induction. |
16th Sep, 2009 at 09:12:22am
I bet thats one of the dodgy batch BK450s. It looks to me that all the fire rings have been blowing.
I seriously doubt it! |
16th Sep, 2009 at 09:28:56am
hmmmmm, I hadn't thought of that Paul, that gasket went on in january, so I thought that was before the manufacturing cock up.
16th Sep, 2009 at 09:41:20am
As above, there appears to be fire ring leakage everywhere.
Edited by T3Tone on 16th Sep, 2009. -MINI CLUBMAN 1380 TURBO- |
16th Sep, 2009 at 09:44:23am
Agreed, it has been blowing between 1-2 and 3-4 as well, just didn't reach total failure as it's slightly stronger at the other two points.
16th Sep, 2009 at 10:49:56am
You may benefit from changing to a 2 core rad as well. Saul Bellow - "A great deal of intelligence can be invested in ignorance when the need for illusion is deep."
16th Sep, 2009 at 11:24:46am
Happy birthday Prawn. Hope you're enjoying your present from payen. lol On 11th Feb, 2015 robert said:
16th Sep, 2009 at 11:43:26am
haha, cheers AP Mr. Prawn, the friendly Crustacean- slowly making steps towards forced induction. |
16th Sep, 2009 at 12:09:49pm
Across all 3! Thats a little odd get your torque wrench checked as well. Own the day
16th Sep, 2009 at 12:56:57pm
Changing the thermostat for a different temperature wont make a blind bit of difference when the engine is running at 100c.
![]() 720 Posts Member #: 2588 Post Whore Pretoria South Africa |
16th Sep, 2009 at 01:24:10pm
I would do as Mr Joshua suggests and check your torgue wrench. "So wat we gonna do tonight Brain?"
16th Sep, 2009 at 01:24:38pm
well. funny you should mention torque, as I had a bit of uncertainty about it when i did torque it down.
16th Sep, 2009 at 01:30:12pm
On 16th Sep, 2009 Sprocket said:
Turbo Dave used to have serious cooling issues that he could not resolve until he changed to a different block, then the problems went away. . I agree Colin, I know it's not going to solve the issue at all, but I thought whilst I'm changing it I'll go for a lower temp anyway. I've run this engine with both large and small water pump pulleys, and 2 core and 4 core rads and it's always run hot. I have a vague memory that when the block was prepared, it was just cleaned in an acid bath type cabinet, and not a proper chemical dip. Just as well I've just bought a complete MPI engine so I can finally get cracking with my supercharged build. Mr. Prawn, the friendly Crustacean- slowly making steps towards forced induction. |
16th Sep, 2009 at 01:35:20pm
On 16th Sep, 2009 Prawn said:
I cleaned up the block first, and put a straight edge on it, and both the block and the head LOOKED ok, although things like that are often very hard to tell! Best way, very old skool, is to find someone who smokes roll-ups and get one of their rizzla papers. I can't remeber if it's the green or the orange (search the net) but one is 1/2thou thick. Cut a thin strip and see if the straight edge traps it at the centre point as you push the straight edge down. A 1 1/2 thou feeler guage isn't accurate enough. Schrödinger's cat - so which one am I ??? |
16th Sep, 2009 at 05:00:11pm
is it me or have you cut the inner wing out? if so this tends to allow re-circulation of the hot air off the radiator resulting in high engine temps. i know mine is a low comp turbo but i sealed the rad to the inner wing, just run an electric fan and the temp struggles to get to "N" on very hot days and then only if stuck in traffic |
388 Posts Member #: 442 Senior Member Manchester |
16th Sep, 2009 at 05:24:43pm
On the subject of detionation, the fuel in germany i believe isnt that good, being of a lower octane. May have caused part of the problem. |
16th Sep, 2009 at 05:52:32pm
On 16th Sep, 2009 mcalvert39 said:
On the subject of detionation, the fuel in germany i believe isnt that good, being of a lower octane. May have caused part of the problem. I remember that one well
Aparantly, Premium at some fuel stations in Germany means 92 octane!! LMFAO On 26th Oct, 2004 TurboDave16v said:
16th Sep, 2009 at 06:03:46pm
Standard German UL is 91 RON, Super is 95, and Super Plus is 98, or at least it was where we went.
16th Sep, 2009 at 06:09:04pm
On 16th Sep, 2009 Tom Fenton said:
Standard German UL is 91 RON, Super is 95, and Super Plus is 98, or at least it was where we went. Exactly Tom. Who can guess what happens when you put 91 or 92 octane in a high performance engine designed for at least 95, perhaps closer to 97 I have seen these results before
17th Sep, 2009 at 06:33:22am
hmmmmmmmmmmm. I wondered why there was super, then super plus! I only ever put in the 98 ron super plus though.
17th Sep, 2009 at 09:00:56am
i wonder if thats too rich for its own good ?
17th Sep, 2009 at 11:41:22am
very interesting point robbet, I hadn't thought about the bonnet shut idea. timing was set on the rollers, with a big fan but bonnet open. the engine was up to normal temp, but nowhere near as high as it's been running lately. Mr. Prawn, the friendly Crustacean- slowly making steps towards forced induction. |
17th Sep, 2009 at 12:03:44pm
looks rcher (blacker) than mine and i'm running 10.5:1 afr under boost On 28th Aug, 2011 Kean said:
17th Sep, 2009 at 01:06:32pm
finer droplets joe ? Medusa + injection = too much torque for the dyno ..https://youtu.be/qg5o0_tJxYM |
17th Sep, 2009 at 09:23:18pm
Right, it's running again!
what a lovely birthday present it is too!
