| Home > Technical Chat > N/A exhaust ports and LCB | |||||||
21st Sep, 2009 at 05:16:23pm
Im tinkering with my exhaust atm and modifying my LCB a bit to get the whole system higher in the tunnel and had a thought.
I seriously doubt it! |
![]() 3756 Posts Member #: 1709 I like granny porn. LONDONSHIRE |
21st Sep, 2009 at 05:27:57pm
why not paul, its not like you dont have the ability..... On 2nd Oct, 2009 Vegard said:
I bet my first wank came quicker than your first mini turbo These new modern turbos with their quick spool up time, would make the competition harder. On 15th Aug, 2011 robert said:
phew!!! thank you brett for smashing in my back doors .( not something i imagined writing... EVER) |
21st Sep, 2009 at 06:27:49pm
I thought a step on outlet from head to manifold on a NA engine helps stop gas reversion, even more beneficial to something using a big dirty camshaft profile?
21st Sep, 2009 at 06:32:00pm
Thats my understanding Tom, but, looking at Vizards diagrams you only get reversion on the floor of the port where the gases are slowest so maybe a smooth transition on the roof and sides would be better.
21st Sep, 2009 at 06:39:45pm
It certainly would make sense, I guess the anti-reversion stuff won't really affect power but may well help torque lower down, I'll be interested to see what you find out really.
21st Sep, 2009 at 06:44:13pm
Tom, Ive sent an email to Maniflow, Ill let you know what they say if they say anything. Ill talk to Swifty too.
784 Posts Member #: 912 Post Whore North Yorkshire |
22nd Sep, 2009 at 03:34:51am
I'd be interested in what Maniflow come back with Paul.
Edited by Si P on 22nd Sep, 2009. I drill holes in everything..! |
22nd Sep, 2009 at 08:27:53am
Si, As long as the inlet is only slightly smaller than the head it wont make much difference on IDA or DCOE, but, if you have a whappy cam you wont really need low down throttle responses as you need to keep the revs up.
22nd Sep, 2009 at 12:23:30pm
Ok, so I cut the mounting flanges off the outer 2 port part of the LCB and bolted them to the head.
22nd Sep, 2009 at 08:02:18pm
I think you theory is sound Paul,
23rd Sep, 2009 at 04:59:44am
What port shapes are you running with on the exhaust side Paul?
23rd Sep, 2009 at 08:13:24am
I guess that this all comes down to the straight length of manifold after head. In our case (apart from Carl who bends the other way) the bend is close to the head and so a benifit could be possible. On a car where the first bend can be further away from the head then it won't have as much benifit (this is not very common though). http://www.twin-turbo.co.uk
23rd Sep, 2009 at 08:35:38am
My outer 2 ports are D shaped, with the curved portion outer most.
23rd Sep, 2009 at 11:49:20am
My ARS is at the gasket face.
23rd Sep, 2009 at 12:18:33pm
I think the correct term is "anti reversion step edge" or ARSE for short......
23rd Sep, 2009 at 12:30:24pm
Was waiting for that Tom.
23rd Sep, 2009 at 12:48:07pm
im quite surprised Paul that you dont use a custom trick lcb already!!
Yes i moved to the darkside |
23rd Sep, 2009 at 09:37:09pm
John haston did indeed have an MED circular ex port head, it was a special with 33mm ex valves, modified inlet calves i beleive were usedand 35.6 race type inlets all on 6mm stems
23rd Sep, 2009 at 10:02:14pm
So did you look into ARSEs Carl?
23rd Sep, 2009 at 10:52:01pm
i also looked into the Benefits Associated with Nitrous Directional Instability Tracts,
23rd Sep, 2009 at 11:34:26pm
On 23rd Sep, 2009 fastcarl said:
i also looked into the Benefits Associated with Nitrous Directional Instability Tracts, so you could say iv'e looked into Arse Bandits, Is that why your pipes bend the wrong way :) I run a supercharger and I don't care the TB is on the wrong side.
24th Sep, 2009 at 12:05:41am
Nice ARSE Paul. lol
24th Sep, 2009 at 08:37:50am
Paul I have done a lot of hours on this very topic If you look at the build thread of my Racer you will see pic of the new Exhaust tunnel I have designed.
On 17th Feb, 2009 Rob H said:
24th Sep, 2009 at 09:14:10am
Si, it steps down after the head so the manifold is bigger than the head on the inner wall and the floor but flush on the outer wall and roof. Google anti reversion dam and lots come up.
