| Home > General Chat > Any Electricians? | |||||||
25th Sep, 2009 at 08:47:47pm
Been having problems with my Spot Welder. I do a couple of spots in quick repetition and the breaker trips. No trouble with the MIG.
Edited by apbellamy on 25th Sep, 2009. On 11th Feb, 2015 robert said:
25th Sep, 2009 at 08:52:47pm
Not a good Electrician myself. Perhaps the spot welder pulls too much of a surge. Where the MIG is more constant. A full 30 amps to the garage will sort it out? I have a B50 trip fitted. Edited by Jason G on 25th Sep, 2009. On 19th Jan, 2010 wil_h said:
![]() 2102 Posts Member #: 432 Post Whore Swindon |
25th Sep, 2009 at 10:21:35pm
try uprating the breaker and see if that helps. Also what rating is the cable to the garage?
67 Posts Member #: 6876 Advanced Member Burton-on-Trent |
26th Sep, 2009 at 12:11:20am
if its a straight swap, ie size for size (physical dimensions) then do it yourself. electricity only bites when you dont respect it!
104.7bhp NA
26th Sep, 2009 at 09:34:22am
Not sure what rating the cabel to the garage is, but I know it's armoured and about 1" thick. The sparky who did the house said it was about twice what I needed even for serious power use.
26th Sep, 2009 at 10:41:32am
On 25th Sep, 2009 apbellamy said:
"current at which this operates is denoted by the letter prefixing the current rating. B type trip at between three and five times the rated current and are generally reserved for domestic and very light commercial use. C type trip between five and ten times the rated current and are used for everything from motors to fluorescent lighting. D type trip between ten and twenty times the rated current and are used for very inductive loads such as very large motors and welding equipment. " The above is true, but a 20A breaker will always trip at 20A constant load. What the letters denote is the way it works, basically the time delay. C or D type allow for large starting currents of inductive machines. I would change it to a C myself. This should not have any effect on your part P as it is just replacing a part not changing the system. The circuit will still be protected to 20A. http://www.twin-turbo.co.uk
26th Sep, 2009 at 10:57:00am
Changing a breaker is a piss ball, just turn the main switch off and then you are working dead, and effectively just changing a fuse.
26th Sep, 2009 at 11:06:03am
Thanks for the advice gent's.
26th Sep, 2009 at 11:10:28am
I had exactly the same at my last house with my SIP spot welder - it has a crappy transformer in it (to keep the size and weight down) and is highly inductive.
26th Sep, 2009 at 11:36:38am
Thanks Rod
26th Sep, 2009 at 06:33:46pm
As said above, i think you may be over the 20A with that unit. Definitely worth swapping for a 30A supply if possible, and a C type breaker also.
20th Oct, 2009 at 06:13:52pm
Finally got this sorted. Spark has been round and put in a 20C rated breaker and Bob's your mother's brother. Spot welding is back on On 11th Feb, 2015 robert said:
