| Home > General Chat > How thick are those thick alloy fan spacers? | |||||||
27th Sep, 2009 at 12:18:41am
Minispares has me confused... Are these things 7/16 or 7/8?
27th Sep, 2009 at 12:48:34am
they are certainly not 7/8 so i'd say 7/16,
27th Sep, 2009 at 01:06:42am
I recon 1/2, so I tend to agree with Carl.
Edited by Sprocket on 27th Sep, 2009. On 26th Oct, 2004 TurboDave16v said:
27th Sep, 2009 at 08:16:01am
Possibly neither....
Edited by Rod S on 27th Sep, 2009. Schrödinger's cat - so which one am I ??? |
27th Sep, 2009 at 08:16:06am
double post..... Edited by Rod S on 27th Sep, 2009. Schrödinger's cat - so which one am I ??? |
27th Sep, 2009 at 09:29:37am
I was going to say that there are at least two types out there:
Edited by Rob H on 27th Sep, 2009. Isambard Kingdom Brunel said:
27th Sep, 2009 at 12:23:49pm
Those are the standard 4mm steel ones as fitted to all 1275 A+ mini engines 1991> On 26th Oct, 2004 TurboDave16v said:
27th Sep, 2009 at 12:29:55pm
Then they are either quoting the wrong part number or have used the wrong photo....
27th Sep, 2009 at 12:31:14pm
Both my clubman estates had these alloy spacers on as standard.
27th Sep, 2009 at 12:38:35pm
I use one on the 998.
Edited by Paul S on 27th Sep, 2009. Saul Bellow - "A great deal of intelligence can be invested in ignorance when the need for illusion is deep."
27th Sep, 2009 at 01:06:44pm
Those metal 4mm spacers I use in the 16v kits when using the MPi pullies. one of those behind the waterpump pulley and one infront of it, moves the pulley out 4mm but keeps the fan exactly where the factory put it Edited by Sprocket on 27th Sep, 2009. On 26th Oct, 2004 TurboDave16v said:
27th Sep, 2009 at 05:21:18pm
that looks like a drive flange off an old pump! |
27th Sep, 2009 at 06:56:56pm
I have no idea what that is off Sprox - never seen one like that!
27th Sep, 2009 at 07:09:32pm
The clubby ones are thicker than 3/8". I'll try to find one and measure. On 13th Jul, 2012 Ben H said:
28th Sep, 2009 at 09:35:13am
There are three 'standard' sizes of spacer - the 4mm steel one, the 12(ish)mm alloy one and then a 16(ish)mm thicker alloy one
![]() 2054 Posts Member #: 452 Post Whore Chester, UK |
28th Sep, 2009 at 10:54:38am
never knew there was 2 types on my old clubman i just bashed the breather tube bit in a bit so the fan cleared and worked a treat. learn something new everyday! |
28th Sep, 2009 at 01:37:40pm
On 28th Sep, 2009 graemec said:
The thinner alloy one was used on cars with the breather on the timing cover, from memory it has a PGX... part number which to me says it was introduced quite a bit later in production. That's interesting - so someone might have realised that two thin steel spacers was a bodge, and designed something to do it properly? I recall pulling a carb'd cooper apart - that had two steel spacers - I assumed it was an owners bodge, not factory... On 17th Nov, 2014 Tom Fenton said:
28th Sep, 2009 at 01:57:45pm
Two steel spacers are fitted by the factory on at least all the 1275s ~ 1991 > On 26th Oct, 2004 TurboDave16v said:
