Home > Help Needed / General Tech Chat > Intercooler getting hot
chinlesswonder
Member #: 1192
In the garage......again!!
Noticed at combe that the pipework and intercooler are getting seriously hot after a thrashing, got a bit of detonation due to charge temps being high.What i want to know is will wrapping the pipework in heatwrap help keep temps down or does it have other effects?.
133.5 bhp 123 lb torque 116mph @6640rpm 9.5psi
Shakespear RWYB 14.995 91.83mph
BadgerBaiter
Member #: 2257
Brighton
Are you allowed to water spray or a cryo spray over the 'cooler on the track? Am thinking no for the water, but a cryo spray may help...?
http://www.jolyonway.com
Nick
Member #: 154
Midlands
i'd say a better intercooler is needed maybe?
or better airflow?
You need to work out if its heat soak or inefficient IC causing the excessive heat.
evolotion
Member #: 83
Glasgow, Scotland
yip, and id hasard a guess at a crap ic .. mine is stone cold as well as popework and inlet after a right good kicking. only time i ever experiece temp-related-det is fi i have been idling in traffic for hours then boot it.
Denis O'Brien.
chinlesswonder
Member #: 1192
Thanks for the replies, i think its a bit of a mixture of the two, crap rs intercooler and heat soak into the pipes. The pipes get so hot you cant touch them.I just thought for a temporary fix until i take it off the road over winter, to wrap them up.
The RS IC is generally considered ok for decent power.
Where is it situated, does it have a decent cold air feed?
The Ic on the TT is hot on one side and cold on the other, just as it should be
My intercooler is hot after it has been sitting for 15 minutes after a hard run. Heat soak is the problem.
It's cold when running at a reasonable speed.
Perhaps this is why some vehicles have fans on their intercoolers for instances such as sitting in traffic.
nuukuus
Member #: 6857
Lieto / Finland
Do you know yours inlet temperature when you drive??
Of course it goes hot when you stop the engine running, then all heat release and if you have aluminium cooler it is hot really soon after the stop.
1399cc, Eaton M45 supercharger, N2O system, compression ratio 9.23:1, boost pressure 0,8bar/11.6psi.
http://www.garaget.org/?car=176816
The RS unit is very good As Will says. Show us a picture of both sides and let's see if that makes things any more obvious...
chinlesswonder
Member #: 1192
couple of pics to illustrate the pipework, looking at it , its not in the best place i suppose
Yes. That location is pants. The air needs to FLOW THROUGH an intercooler for it to be effective. Little to nothing will flow through that. Very little air flows over the top of the engine as there is nowhere for it to escape (a fundamental requirement of 'flow').
Now, if you were to run without a bonnet, this would be a LOT better.
