Home > Help Needed / General Tech Chat > Metro Fuel Pump - direction of flow
Got one of the replica Metro Trubo fuel pumps, but it's not marked up with a flow direction.
Which end is in? The end with the wires, or the other end?
Done a search but couldn't find anything...
EDIT - One of these:
http://cgi.ebay.co.uk/NEW-Electric-Fuel-pe...id=p3286.c0.m14
Edited by apbellamy on 28th Sep, 2009.
In through the big end, out through the small end.
I'll take it of and fit it the right way round then....
Thanks Tom
Thanks Tom
:its an easy mistake to make and one you dont forget*tongue* especial when its marked up wrong like mine was aswell*happy*
Mr Joshua
Member #: 1954
Luton Bedfordshire
The Outlet from the tank needs to be the same Id as the inlet of the pump. If you utilise the original tank outlet you stand a very good chance of cavitating the pump. GinoR32's tank is a good example
http://www.turbominis.co.uk/forums/index.php?p=vt&tid=314421
Edited by Mr Joshua on 28th Sep, 2009.
Own the day
So... I'm going to have to bastardise my sender after all and get some 8mm pipe in there some how...
I wouldn't worry about it. Austin Rover certainly didn't on the original Metro Turbo. As long the the outlet from the tank has a decent head of fuel it will work fine.
Mr Joshua
Member #: 1954
Luton Bedfordshire
its not that hard you can source all the fittings from B & Q.
I just used stainless as I'm a Magpie *happy*
Own the day
My plan was:
8mm hose orginal tank sender to T piece.
8mm hose from T to filter.
8mm hose from filter to pump.
8mm hose from pump clamped down ( 3 clamps and a big overlap) to the original 6mm supply pipe.
run a 8mm copper return
8mm hose from return to T piece.
Does anybody see a problem with this setup as I'm kind of under the car doing it now (not right now thus second, but you know what I mean)...
It's on the metro van BTW.
i used the feed from a std mini tank iirc 6mm :) i ran it up to 12psi boost, didnt have any running probs tbh untill it broke i dont know why it did that *tongue*
