| Home > Help Needed / General Tech Chat > Ignition Management Systems | |||||||
![]() 2054 Posts Member #: 452 Post Whore Chester, UK |
30th Sep, 2009 at 03:02:17pm
Hi
30th Sep, 2009 at 03:06:32pm
Do you have a link to the Storm kit ???
30th Sep, 2009 at 03:09:39pm
hi
Edited by t@z on 30th Sep, 2009. |
30th Sep, 2009 at 03:20:36pm
OK yes, from a quick read of the link, a coilpack driven direct from the ECU rather than through an EDIS unit.
30th Sep, 2009 at 04:07:26pm
Does the Storm also need the additional MAP sensor?
30th Sep, 2009 at 06:10:35pm
must admit hadnt thought about a MAP sensor just assumed it would come with one as i cant imagine many mini owners use TPS. pictures to small also to work out.
30th Sep, 2009 at 06:31:08pm
On 30th Sep, 2009 t@z said:
Rod does that mean that a direct driven coilpack is better than an edis one like the MJ? Well, people will have opinions, but I would say yes - providing it's implemented correctly in the ECU/package. EDIS was a half way house, Ford's don't use it anymore, their ignition is now done directly from the EMS/ECU module. It had it's advantages at the time (ie, a fail safe / limp home 10 degree advance if EDIS lost the command signal) but putting half the system in one box and the other half in another box is a bit dated. Also, as a general rule, you will have a lot more control over certain functions (like charge/dwell time) when the ECU is controlling the coilpack directly. Also, the wiring becomes a lot simpler.... Just my opinion but I'm running Megasquirt with direct control of the coilpack so I may be a bit biased :) Schrödinger's cat - so which one am I ??? |
![]() 334 Posts Member #: 7169 Gobshite that posts wank videos. Somerset, UK |
30th Sep, 2009 at 07:00:39pm
Looks like you can buy a MAP sensor for it as an extra so it obviously has the capability to use one :) Gaball said:
Motorsport Engineering Student Project Car 1293 Turbo Mini (on a student budget) On 7th Oct, 2010 apbellamy said:
Carbon but plug? |
30th Sep, 2009 at 07:24:36pm
I am assuming the "A series specific package" includes the A series coil and HT leads Gaball said:
Carbon but plug? |
1st Oct, 2009 at 09:43:40am
wowweeee so that MAP sensor pushes it to 400+.
Edited by t@z on 1st Oct, 2009. |
1st Oct, 2009 at 10:47:16am
After having a look at the SC kit at the Pod, all their stuff has evolved massively. The twin cam kit is almost a bolt-on job now. I'm sure you won't have any fitting problems this time round On 12th Nov, 2009 Paul S said:
Gary's description is best |
1st Oct, 2009 at 11:28:37am
actually i have an incline that the a series package contains the map sensor also which is why its a bit more.
1st Oct, 2009 at 11:34:39am
He does read here quite regularly. I'm sure he will see the thread next time he is on or maybe you could drop him a PM On 12th Nov, 2009 Paul S said:
1425 Posts Member #: 690 Post Whore Norfolk |
1st Oct, 2009 at 03:49:50pm
ok the Storm ignition kit for the Mini A series comprises
If Carling made Mini engines
1st Oct, 2009 at 04:36:38pm
All that shite went straight over my head! Im sticking with a dizzy for now, it still does the job
I seriously doubt it! |
1st Oct, 2009 at 04:43:08pm
Do you not think mapped ignition would improve your 1/4's Paul? If something is worth doing, it's worth doing half of. |
1st Oct, 2009 at 04:46:37pm
Not if I dont know how it works I seriously doubt it! |
1st Oct, 2009 at 04:50:47pm
Maybe you should investigate if you have some spare time If something is worth doing, it's worth doing half of. |
1st Oct, 2009 at 04:56:39pm
Ive read about it loads of times but it still goes over my head.
1st Oct, 2009 at 04:59:07pm
I wish I could use spanners & hammers half as well as you mate! If something is worth doing, it's worth doing half of. |
1st Oct, 2009 at 05:17:18pm
On 1st Oct, 2009 paul wiginton said:
All that shite went straight over my head! Im sticking with a dizzy for now, it still does the job Paul Ah, get your finger out Paul. There is nothing more complex to megajolt than a dizzy. If you buy something with a pre-built loom them it's very easy to fit. Then bring it to a rolling road for mapping On 12th Nov, 2009 Paul S said:
1st Oct, 2009 at 05:31:44pm
On 1st Oct, 2009 johnK said:
ok the Storm ignition kit for the Mini A series comprises ECU with CAN interface/software/basemap etc Loom (same loom for MAP or TPS) Trigger kit + sensor (see pics of K engine in show us yours section for new trigger wheel) due to people running turbo's webers, su's etc options are needed! so the SU HIF TPS kit is £70 the Weber DCOE TPS kit is £59 coil/leads/A series billet bracket £79 MAP sensor £55 Hope this helps - if you need any techie help please give us a call on 01953 859785 cheers JK Options are extra costs? what i'm trying to do is justify it...so currently if i went with your kit i'm looking at. A series kit: £345 Map Sensor £55 Coil Pack £15 Total £415 At the moment all i can see the difference is that you lose the EDIS (which is nice) and no wiring (also nice) but not £135 nice if you get me. obviously not used your software i can't say if its better but if i'm honest i wouldn't be mapping it anyway so its not a big concern of mine just got to go to a good place. its a shame as i love the ease and simplicity of this product so much but i just cant warrant parting with that much when there doesn't appear to be that bigger plus's that i can see.....i want someone to prove me wrong on this :) Paul, i think you should fit it and let the RR do the tech stuff. i'm no expert at wiring ask supermottolee and even i managed to wire a MJ up with his help. t |
1st Oct, 2009 at 05:44:27pm
One problem is that all the sets Ive seen have shit looking wiring, the other thing is which to go for, many on here use MJ with great success, others say its shit, use a quality DTA.
1st Oct, 2009 at 05:48:23pm
Dave, I'll happily explain it to you, ask away via PM if you wish.
1st Oct, 2009 at 05:52:03pm
Will do Tom, but will have to try to think what to ask. Firstly whats the difference between MJ, Weber and DTA and their benefits I guess
