Home > Technical Chat > carb damper oil
jom
Member #: 6003
how much oil should i put in there?which oil?i use hif 44 carb. is it depend on the spring?
MarkGTT
Member #: 1194
Shropshire.
very difficult to say what oil, depends on the engine spec etc.
im wondering this myself atm
i believe most use engine oil tbh, i.e. 50wt
but some say sewing machine oil is best, or 3 in 1, others hydraulic oil, you can even buy specific "SU oil" from burlen
in my mind, just try what you have got to hand, then just trial and error to see what gives better throttle responce
bear in mind synthetic oil will be more stable through the various temp ranges the carb will endure, whereas mineral's characteristics change a fair bit at extreme temps
tbh though, ive never found a carb ''too hot to touch, so doubt it really matters all that much (although mineral might be a tad thick when very cold?)
jom
Member #: 6003
well, i will put 3in1 oil,see any different
MarkGTT
Member #: 1194
Shropshire.
This was key for me, 40w was to thin and became unstable when hot, i now use a motor bike gear box oil 80/90w a tad rich on cruise but about right on boost and WOT.
Edited by MarkGTT on 2nd Oct, 2009.
I have found that you need thicker oil with boost too, I use similar to Mark.
turbominivanman
Member #: 1504
Westbury, Wiltshire
Good results with Valvoline VR-1 20W/50 engine oil in mine.
Richard.
jom
Member #: 6003
so 3in1 oil ist thick enough for turbo carb?
i had to take it out, i have some 20/50 in there, 3 in 1 made a bad flat spot then going to full throttle
edit sorry mine n/a but i ran regular engine oil in my tubbie too
Edited by Brett on 2nd Oct, 2009.
stefaz
Member #: 1656
stoke-on-trent
Am I the only one that uses genuine SU oil then? It seems to work well on the n/a daily, will have to see about the turbo
Star Mag
Member #: 375
Leicestershire
I just use the same as goes in the engine. I suppose it all depends on what it has been tuned with in the first place.
I tried genuine SU oil - never could get it to work with the turbo. Ended up using the nice bottle the SU oil came in and Engine oil.
Turbo Tel
Member #: 588
Delaware, USA
Genuine SU oil is 20wt.
Basically any oil will do but you need to have a complementary needle profile so 20/50 is a good bet, its a little thicker which helps with the turbo. Thin oil is used by N/A racers to speed up the throttle response, but they have to reprofile the needle to suit it and that causes compromises that are not usually acceptable on a road car.
Terry
MarkGTT
Member #: 1194
Shropshire.
Hi Terry, i found you needle profiling tips and extensive 'step by step' guide very helpful when setting up my carb. (thanks)
the throttle response on mine seems ok.. but looks like i tend to use a much thicker oil than most, would you suggest experimenting with something thinner and re-profiling the needle a bit more??
is this likely to make improvments?
Ive heard brake fluid is good but Ive never tried it
Paul
I found its the heat and then the cold that effected the oil and then the mixture.
no such issues with the bike carb.
Turbo Tel
Member #: 588
Delaware, USA
Hard to say, If its working OK then I would not worry about it, the needle and oil are matched.
What I did see with thickest oils was a tendancy to lean out in top gear, My theory is that in 1,2 and to a leser extent 3 you are only on the throttle for a short time and the piston never really catches up. However for the mixture to be right the needle needs to be a shade lean. But in top you tend to be holding WOT for much longer and once it catches up it can expose the lean needle.
Terry
Turbo Tel
Member #: 588
Delaware, USA
I'm beginning to think its not the dashpot oil getting hot (or cold) but the density of the air. With cold dense air in the winter the fuel/air ratio is leaned up, it hesitates and I am finding thicker oil is needed, kinda opposite what I imagined, i.e that in winter I would need to use thinner oil to counteract the higher viscosity of cold oil..
Terry
I dont know but it would go from very think to very thin. I tried all sorts of stuff. even the millers CTV as I was thinking it could take the heat better.
IMO the bike carb is a better design, but it is newer, the fact you dont need oil also means you never need to top it up. Even with a NOS piston, dash pot and plunger it would use oil, depending on how I drove the car. The problem I had was it would hesitate all of a sudden and then I would be checking everything again, like has the choke seals gone, is there oil in the dash pot, needle, etc. For a novice like me it would do my head in.
Then again the bike carb isn't turbo friendly its just that I can use an N/A version, due to my conversion.
All I can say is the car has been much better on the KVP carb.
But then like everything is all getting old and you need to keep stuff in good condition.
What ever suits your application best.
